BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
07-14-2009, 00:07 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1073598 Status: Offline Thanks Meter: 0 | Multiloader failes to reconnect I hope someone here can help me. I have a T-Mobile Blackberry 8900 (newer model) Every time I use Multiloader it fails at what appears to be near the end when it says "attempting full reconnect". I have the correct configuration file from here and the correct files in the MML folder. I also deleted the vendor file and unplugged the ethernet cable. After it fails, I'm stuck with the white screen on the blackberry. I believe it says "no factory os installed" From there I can attempt to use multiloader again or use Desktop Manager to restore the phone. I've also attempted restoring the phone using the /noJVM command but once everything was done, the phone was still locked to T-Mobile carrier only. Any suggestions? It appears as though most the steps in Multiloader work fine but once it attempts a full reconnect, it fails. Last edited by narc0tics; 07-14-2009 at 00:15. |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
8100 "unable to reconnect to the device during a multi-stage load operation" | narenintouch | BlackBerry (RIM) | 6 | 12-12-2009 10:02 |
MFI Multiloader failed | scoobee | BlackBerry (RIM) | 10 | 11-30-2009 11:15 |
(Help) MUlTILOADER FAIL | willyzhu | BlackBerry (RIM) | 0 | 03-23-2009 19:27 |
HELP MFI Multiloader FAILS EVERYTIME | lisurfer87 | BlackBerry (RIM) | 2 | 01-20-2009 04:08 |
