DB2020 Unlocking Started in Setool I am proud to be announce on behalf of setool's team that now we can unlock any DB2020 with setool in 37US$ and 12 credits. How to unlock DB2020 phones with server. (pls note price for DB2020 unlock 12 credits!) Step 1: select USB as interface. that is REQUIRED. Step 2: select K610 as phone model (or any other DB2020 model, they are same) Step 3: |settings - check "use server for csca unlock/flash", "do full unlock instead of user code reset for DB2020", fill your login details. Step 4: back to semc tab, press unlock, attach phone with pressed "C" (or 2+5) buttons. Step 5: wait for signature calculation, it can took about 2 minute. If calculation will fail, your credits will NOT be deducted. if calculation is success, then signature will be saved in backup\%imei% folder in your setool2 directory. Step 6: next, you will be prompted to detach phone and turn it on. do so. detach phone. turn it on FULLY phone will be on 5 locks, that is normal. Step 7: connect phone to USB. if phone will ask you switch to phone mode - switch to phone mode. it can ask you for drivers,if you not installed them previously. install all drivers (links below) be SURE that you install all drivers correctly. Step 8: press "test point OK" procedure will continue,phone will be switched off and unlocked. !note. DB2020 unlock supported on both servers .196 and .198 remember, if something will go wrong - you have a backup of security units for now price for DB2020 unlock 12 credits (36 usd) BR Kashif Khan |
thank u very much brother for help |
Thx Kashif Khan for this Tutorial, it's soooo help full !!! And we wait the solution from Cruiser Team Too ... ! Thank you again Kashif Khan |
very useful mate. I'd like to have solutions from Cruiser team as well |
