the game could not be started(80020321) psp hi!! i make update for my psp 2004 version 5.50 gen-c (full) and when try to play games i have error the game could not be started(80020321) can you help me ? |
did you tried this This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load. Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error. |
i don't have experience with psp but i have repaired this problem before in ma psp 5.03GEN-A its too hard but you will do it if you have some patient finally in this SITE you will find all what you need to hack your PSP Good Luck Br Ahmed |
I am having same problems as of now after updating PSP 2000 with gen d3 old games disappeared and remainning games were corrupted |
hey people iv got the solution : This is what you do : when you are on the main menu (xmb) press select and this menu will open change teh things on the menu to this : CPU CLOCK XMB - 333/166 CPU CLOCK GAME - 333/166 USB DEVICE - MEMORY STICK UMD ISO MODE - SONY NP9660 ISO VIDEO MOUNT - NONE USE DIRECTION PAD TO CHANGE THE OPTIONS LEFT/RIGHT |
CPU CLOCK GAME - Default USB DEVICE - MEMORY STICK UMD ISO MODE - SONY NP9660 / M33 Driver ISO VIDEO MOUNT - NONE U may get error on others game if u do not use the following rules. and try install ******* firmware promethus-4. it can run require f/w 6.35 |
