Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 09-02-2009, 09:39   #1 (permalink)
coldGin's Avatar
Member: 1035797
Thanks Meter: 351
GUIDE How to Reprogram/Recover or Flashing MP4 MP5 Player
Here is an step-by-step tutorial on how to identify your MP4 player, download its firmware and flash it using appropriate tools :
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
  1. The most important step of the whole process is to correctly identify your device CONTROL CHIP and CPU, using wrong firmware or flashing tool may cause damage to your device, unscrew and open your device and write down all chip id's and motherboard numbers you see, you can also try the EasyChips - firmware identification utility but it did not worked for me.
  2. You will now need to download the correct firmware and flashing utility for your device, visit sites below and search for your control chip and cpu to download the firmware and flashing utility, you can also post on user-forums to get help identifying the firmware :
  3. In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
  4. Once identified you need to connect your device to computer via USB in camera mode (Press A + OK button and plugin USB cord on player), for Windows to identify this mode you will need camera drivers you need to point Windows Found New Hardware Wizard to Driver folder downloaded with the FRM Pro utility above, this will install the first camera driver, for correct identification by flashing utility you need to install a second camera driver - open Windows Hardware Manager and install unidentified camera device drivers by pointing the driver wizard to Driver folder used earlier.
  5. Now install and launch FSM Pro flashing utility and follow these instructions to install the new firmware.
  6. Let the process finish, this will take a while, do not disconnect or interrupt the process until you see a success message in log window.
  7. Unplug your PMP from computer and it should be working now.
Another guide For Beginners
The Following 21 Users Say Thank You to coldGin For This Useful Post:
Old 09-04-2009, 11:04   #2 (permalink)
Member: 1109964
Thanks Meter: 9
thanks for this guide . . .
can i use this to revive a dead mp4 player?
The Following User Says Thank You to jack214 For This Useful Post:
Old 09-04-2009, 11:08   #3 (permalink)
Member: 1109964
Thanks Meter: 9
Old 09-06-2009, 06:13   #4 (permalink)
Member: 525482
Thanks Meter: 21
hi thx for this tips but after flashing player has no display only white display
The Following User Says Thank You to paresh007 For This Useful Post:
Old 09-06-2009, 06:35   #5 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
nice posting.... i hope will help others for very usefull thread like this. thankz for master rey misteryo
The Following User Says Thank You to Ligalig For This Useful Post:
Old 09-06-2009, 08:52   #6 (permalink)
coldGin's Avatar
Member: 1035797
Thanks Meter: 351
look for the right firmware.
The Following User Says Thank You to coldGin For This Useful Post:
Old 09-08-2009, 15:45   #7 (permalink)
Member: 525482
Thanks Meter: 21
plz giv eme right f/w
my cpu is sunplus spmp 3052a hl171
lcd cmt304 08 08 18
plz give me this f/e plzp lz
Old 09-10-2009, 03:05   #8 (permalink)
coldGin's Avatar
Member: 1035797
Thanks Meter: 351
yes it is the solution if the problm is software.
for hardware problem search the forum there are lots of threads regarding hardware problem.
Old 09-27-2009, 12:18   #9 (permalink)
Member: 1128370
Sonork: 6ed9ff415f56e41711fa73bd1
Thanks Meter: 3
Tnx bossing I have idea after reading the instruction.
The Following User Says Thank You to ako_account For This Useful Post:
Old 09-27-2009, 12:19   #10 (permalink)
Member: 1128370
Thanks Meter: 3
Im asking How to reformat mp4 mp5.... I had so much time in finding the program.
Old 10-17-2009, 07:31   #11 (permalink)
Member: 1136985
Thanks Meter: 2
I need frimware for mp5:
spmp3052b-hl171
0909
m191S04
CAM:XHB7678F
Board:280-V12 081230
The Following 2 Users Say Thank You to abderrezak32 For This Useful Post:
Old 10-17-2009, 09:42   #12 (permalink)
coldGin's Avatar
Member: 1035797
Thanks Meter: 351
spmp3052b-hl171
0909
m191S04
CAM:XHB7678F
search here
http://forum.gsmhosting.com/vbb/show...=778270&page=3
try this
http://www.megaupload.com/?d=QM1P1N04
The Following 2 Users Say Thank You to coldGin For This Useful Post:
Old 10-24-2009, 13:18   #13 (permalink)
Member: 1148473
the firmware you judge may not be compatible with the player...try another firmware
Old 10-24-2009, 15:46   #14 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
How about mp4 bug in hourglass Bro? need help for trick!!!
Thanks
Old 10-29-2009, 03:07   #15 (permalink)
coldGin's Avatar
Member: 1035797
Thanks Meter: 351
Thanks
http://forum.gsmhosting.com/vbb/showthread.php?t=561382
http://forum.gsmhosting.com/vbb/showthread.php?t=565120
http://forum.gsmhosting.com/vbb/showthread.php?t=548863
DV MP4/MP5 player flashing manual farihabest Game Consoles & Mp3/4 , HD players 1 07-13-2015 09:54
sony/dv mp4 mp5 player Problem MR_Rovel Game Consoles & Mp3/4 , HD players 2 09-06-2009 13:13
dv mp4 mp5 player MR_Rovel Game Consoles & Mp3/4 , HD players 0 07-08-2009 11:16
Share GUIDE - How to convert DVD or videos to iPod video format join1982 Off Topic Zone 3 04-24-2008 06:08
Page generated in 0.22732 seconds with 10 queries
