~PSP Upgrader & Downgrader Tools~ “Chronoswitch” Downgrader 5.0.f Advanced 09g Support! This multi-firmware downgrader allows you to install a lower (or higher) firmware without any fuss. No complex flash0 sharing, just running the firmware update. However, there comes restriction with PSP models and compatible firmware. For example, a PSPgo cannot run 1.50 as there are no drivers for the system and the IPL format is incompatible. Much like this, the PSP 3000 09g is unable to install firmwares < 6.30 which removes it’s ability to appreciate the flexibility of permanent custom firmware. "Frostegater's" Downgrader TA-095v2 to 620 fix This is a small Description offer by the Developer himself on how to use Downgrading TA-095v2 to 6.20 FIX for your PSP . 1. Look for FuseCFG by PSPIdent. 2. If your FuseCFG: 0x00002A00, you can downgrade you PSP by Davee’s Chronoswitch Downgrader v5.0f. 3. If your FuseCFG 0×00003300, 0x00003B00 or other, download pre-downgrader-fix, install and press X. 4. After using PRE-Downgrader, you can use Davee’s Chronoswitch Downgrader v5.0f for downgrade. PSP - TA-095 / 09g Upgrader Fix. TA-095 - 09g Physical Upgrader has been released by developer Frostegater, this tool will help PSP-3000 TA-095 (09g) owner, who have downgraded with Davee's Chronoswitch, and get an error IDXFFFFFFFF when try upgrading back to the newer OFW 6.3x or 6.60.. I myself have not tried this, but some preach this worked.. |
~PSP Upgrader & Downgrader Tools~ “Chronoswitch” Downgrader 5.0.f Advanced 09g Support! http://file4sharing.com:182/d/rwnwto...version_5f.rar This multi-firmware downgrader allows you to install a lower (or higher) firmware without any fuss. No complex flash0 sharing, just running the firmware update. However, there comes restriction with PSP models and compatible firmware. For example, a PSPgo cannot run 1.50 as there are no drivers for the system and the IPL format is incompatible. Much like this, the PSP 3000 09g is unable to install firmwares < 6.30 which removes it’s ability to appreciate the flexibility of permanent custom firmware. "Frostegater's" Downgrader TA-095v2 to 620 fix http://file4sharing.com:182/d/rsnwro...grader-fix.zip This is a small Description offer by the Developer himself on how to use Downgrading TA-095v2 to 6.20 FIX for your PSP . 1. Look for FuseCFG by PSPIdent. 2. If your FuseCFG: 0x00002A00, you can downgrade you PSP by Davee’s Chronoswitch Downgrader v5.0f. 3. If your FuseCFG 0×00003300, 0x00003B00 or other, download pre-downgrader-fix, install and press X. 4. After using PRE-Downgrader, you can use Davee’s Chronoswitch Downgrader v5.0f for downgrade. PSP - TA-095 / 09g Upgrader Fix. http://file4sharing.com:182/d/rwnw5o...5_upgrader.rar TA-095 - 09g Physical Upgrader has been released by developer Frostegater, this tool will help PSP-3000 TA-095 (09g) owner, who have downgraded with Davee's Chronoswitch, and get an error IDXFFFFFFFF when try upgrading back to the newer OFW 6.3x or 6.60.. I myself have not tried this, but some preach this worked.. |
PSP stuff here... |
sir how to download this file... need files thanks sir..,., |
DepositFiles |
Download Here or DepositFiles 620PRO-B10fix.rar DepositFiles Chronoswitch Downgrader 09g Support version_5f.rar DepositFiles pre-downgrader-fix.zip DepositFiles PSP.Module.Checker.3.0.rar DepositFiles 620PRO-C2.rar DepositFiles 639PRO-C2.rar DepositFiles PSPCFW-6.XX-***-II-HEN-Fixed.zip DepositFiles Model Generation Compatiblity.txt DepositFiles Installing 6.20 PRO-x Permanent .txt DepositFiles Tutorial.rar DepositFiles 660PRO-C2.rar DepositFiles 635PRO-C2.rar DepositFiles PSP CFW 6.XX PRO MOD B10.rar |
hi any have a video instrucction for the repair software |
vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
