Garmin on Nokia 6210 I installed Gmobilext on my Nokia 6210. It says unable to open file due too security reasons. Wat can i do? |
edit- double post sorry |
Did you install the application in memory card mode like here?:confused: Ensure Nokia PC suite is installed on your PC Connect phone to PC via USB Cable. PC Finds phone Phone external display gives two options 1) PC Suite 2) Data Transfer YOU WANT OPTION 2 The phone will display 'Any ongoing data...etc ' - You choose OK The phone will display 'USB data transfer....ect' - You choose OK More infos here as well.Good luck http://forum.gsmhosting.com/vbb/show...&postcount=220 |
I did install it on memory card. Used the procedure as described. It works on 6110 navi, but wont work on 6210. How can i solve this problem? |
Hi Wynsak, Give this a try. Menu | Tools | Settings | Applications | App. Manager and change Software Installation to All. Change Online certificate check to Off. Hope this helps. |
