GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
11-30-2007, 22:37 | #227 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 433671 Status: Offline Thanks Meter: 118 | Quote:
11-30-2007, 22:48 | #229 (permalink) | |
Maps are all locked. You'll need a key to unlock it for use on Mapsource on the PC. Enter Demo to use the NA NT 2008. | |
11-30-2007, 23:11 | #230 (permalink) |
Junior Member Join Date: May 2007
Member: 501414 Status: Offline Thanks Meter: 0 | I downloaded the software and it is installed successfully. I got my GPS working. I got the map but not the detailed one. So i am thinking that my map is faulty (North America NT). I am downloading from ISO hunt. DO i have to run some unlocking wizard and if so which one and how. DO i have to unlock the map on my PC and then copy it on pocket pc. As i copy the map from one of friends garmin device. I copy that map to garmin folder on my pocket pc and after that i got just a general map not the detailed one. Can some one help me.TIA Last edited by TENACIOUS; 11-30-2007 at 23:16. |
12-01-2007, 00:27 | #231 (permalink) | |
When you run GarminXT, it will find the map, and will require the second unlock key (in Gmapsupp.unl file on your GPS), specific to your IMEI/Unit ID/Media ID that you will need to generate with the keygen to unlock this map. Many scammers release the maps with the PC key, and ask for $ for the GPS key (gmapsupp.unl). You can calculate the GPS key yourself. Copied maps, in the .img format, from one MMC to another will only require the GPS key (in gmapsupp.unl) to work. This key will again need to be calculated specific for your device. | |
12-01-2007, 01:45 | #232 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
http://forum.gsmhosting.com/vbb/show...&postcount=165 Download and install on your PC, the code to unlock on PC is GNG55 - L8WSA - S7YET - 9U246 - GJFQT Now you need to make the GMAPSUPP.UNL using keygen and put that on your phone in Garmin's directory folder. | |
12-01-2007, 06:53 | #235 (permalink) |
Junior Member Join Date: Sep 2005 Location: Georgia
Member: 182026 Status: Offline Thanks Meter: 0 | I seem to be having a rough time getting this to work also. I finished downloading the torrent for City Navigator North America NT 2008 and MapSource allows me to open and select maps to transfer. Even though I've ran the activation code posted several times in both the Unlock Wizard and through MapSource, I get a popup that asks if I want to transfer the maps in demo mode. Doing so results in the GPS being disabled when it finds the maps on my card in my phone. Is there something obvious I'm missing? I've also had no luck using the keygen to activate my own codes. Only the code posted allows me to progress through the activation process. |
12-01-2007, 08:43 | #236 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Poland Age: 64
Member: 58460 Status: Offline Thanks Meter: 23 | Garmin Mobile XT Europemap v9.0 JUST ENTPACK AND COPY MAP IN THE GARMIN DIR pw:eugenia rapidshare.com/files/69475320/eugenia.part01.rar.html rapidshare.com/files/69481414/eugenia.part02.rar.html rapidshare.com/files/69486753/eugenia.part03.rar.html rapidshare.com/files/69495317/eugenia.part04.rar.html rapidshare.com/files/69502954/eugenia.part05.rar.html rapidshare.com/files/69509547/eugenia.part06.rar.html rapidshare.com/files/69522886/eugenia.part07.rar.html rapidshare.com/files/69532727/eugenia.part08.rar.html rapidshare.com/files/69589191/eugenia.part09.rar.html rapidshare.com/files/69593138/eugenia.part10.rar.html rapidshare.com/files/69597642/eugenia.part11.rar.html |
The Following User Says Thank You to Teleserwis For This Useful Post: |
12-01-2007, 14:18 | #237 (permalink) | |
Member: 501414 Status: Offline Thanks Meter: 0 | Quote:
Thanx Ozling and titan05 for your help. The above mentioned link is not working. I am aable to download but when i try to open the zip file i get the message that zip file corrupt or file transfer failure. Is it possible to post the fresh link. Thanx | |
12-01-2007, 15:58 | #240 (permalink) | |
Insane Poster Join Date: Sep 2007
Member: 588212 Status: Offline Thanks Meter: 8 | Quote:
I think i know what the problem is.. Just go into the menu on the phone. Go into your memory card, and take a look at the two txt filen you copied over there. They say ".txt" at the end. Rename them, delete ".txt" after both files and it works.... | |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
help with Garmin XT 4.10.60 S60 please?? | se1boy | GPS devices , Navigators & Maps | 22 | 06-23-2008 05:48 |
Garmin XT 4.10.80 (taiwan) | titan05 | Nokia Multimedia | 5 | 03-23-2008 04:27 |
Garmin XT 4.10.60 S60 | deankanonik | GPS devices , Navigators & Maps | 9 | 01-09-2008 22:01 |
Garmin XT 4.10.20 PROBLEM | slososk | GPS devices , Navigators & Maps | 14 | 12-28-2007 00:41 |
