Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-24-2008, 13:41   #946 (permalink)
Member: 134445
Can someone post link for Switzerland map CityNavigator.
Old 01-24-2008, 16:36   #947 (permalink)
Member: 687965
Think im doing something wrong as i am unable to install Garmin_Mobile_XT__Symbian_S60_v4[1].10.20 When i click on the set up file i get a message saying UserData.dll was not found but i can install the later .60 version. Do i need to install the earlyer virsion and if so what am i doing wrong. Cheer.
Old 01-24-2008, 18:06   #948 (permalink)
Member: 668701
Originally Posted by Ozling View Post
With basemap and an unlocked map (or free map), you will need to fire up your GPSr in the map's coverage area for road etc to start showing. Otherwise, it defaults to areas that you may not have a map for, eg Europe.
Alternatively, you can also zoom out until you can see the areas with map, and the move the cursor over the area before zooming in.
Hi Ozling, thanks for the headsup. In the view map, it says no map?
BTW, wondering if there's anyone from KL that has a BT GPSr that can be 'loan' for a while to test if it works?
I'm in the midst of looking for one, but I'm affraid that I can't get it to work or if it's not worthwhile for me to invest in one.
Otherwise, have no choice but to get a standalone unit
Old 01-24-2008, 20:57   #949 (permalink)
Member: 682631
CAN I ASK WHAT DOES Speed Camera's POI'S DO?
IS IT NECESSARY ?
AND WHAT ARE ITS BENEFITS ?
Old 01-24-2008, 21:15   #950 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
IS IT NECESSARY ?
It will give you a WARNING when you are near a speed camera. Not necessary but good to have.
Old 01-24-2008, 21:30   #951 (permalink)
Member: 682631
REALLY IS
I REALLY THANK YOU
IS THERE ANY OTHER POI'S?
Old 01-24-2008, 23:38   #952 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
REALLY IS
I REALLY THANK YOU
yes there is load of poi's available
and you can download the poi loader for garmin from this thread (i posted it some time ago, just look)
Old 01-25-2008, 01:31   #953 (permalink)
Member: 153856
Originally Posted by cc909 View Post
Thanks dude,
So to summarize, make one SW.UNL and 2 of the Map unlocks on the phone.
1st set of map is GMAPSUPP.IMG + GMAPSUPP.UNL
2nd set of map is GMAPSUP2.IMG + GMAPSUP2.UNL
right??
why i cannot see gmapsup2.img? my device never erecognizes it. allwas just one map.
Old 01-25-2008, 02:02   #954 (permalink)
Member: 688543
Originally Posted by bkewl View Post
Nope - haven't had detailed maps yet.
I uninstalled everything and started over. Here's what I did:
1) Install Mobile XT: GarminMobileXTforWindowsMobile_41040w
- chose storage card
2) Start Garmin, look in About and get ID
3) run KeyGen:
- Calculate the key and create your sw.unl file
- Calculate the key and create your GMAPSUPP.UNL
chose City Navigator North America NT 2008
- Copied 2 above files to Garmin Root of storage Card (no .txt)
4) Install base map: GarminMobileXTFreeBasemap_4***x.exe
- gmapbmap.img was installed
5) Garmin MapSource - choose a couple states then transfer
Start application and get:
Can't unlock maps for garmen device with unit id: ******xx - OK
Obviously doing something wrong but have no idea what.
I tried running KeyGen, put in my Devide ID, generate new numbers (everytime generates new numbers) I get same results.
Ideas?
Hi everyone, just joined today, and this is my 3rd site trying to get this to work on my N82, ive read pretty much everything in this thread, and the reason im quoting this is because ive pretty much done everything this user did, my problem is that when i try to transfer maps to my phone, theyre constantly being transferred in DEMO MODE, i was told previously that i should be able to enter an unlock code in the ABOUT section where the UNLOCK ESN is found, but im not able to unlock anything from there, i dont know waht to do, ive been at this for a month, so please, any help will be greatly appreciated, as i cant figure out why its DEMO ONLY when ive followed the instructions properly
Old 01-25-2008, 04:03   #955 (permalink)
cc3
Member: 684386
Originally Posted by BuMobiles View Post
Look at the picture i've posted to help you generate unlock codes for garmin xt
i have also attached your unlock code extract and copy to the garmin folder on the memory card
Hi BuMobiles,
thanks for the help!
After the SW.UNL u gave, but still doesn't work! I just trying using Bluesky the BT and GPSr is working fine..
any Idea, what wrong?
Please kindly advise.
thank you!
cheer!
Old 01-25-2008, 04:57   #956 (permalink)
Member: 433671
Thanks Meter: 118
If you get the no map, it mean either:
1) No basemap installed.
2) No compatible maps in the .img format in the garmin folder.
The free map from malsing in the gmapsupp.img can just be copied to the garmin folder in your mmc. Just make sure you have a basemap installed.
Old 01-25-2008, 05:03   #957 (permalink)
Member: 433671
Thanks Meter: 118
You should not see this if you are using the correct version of the program. Garmin4.10.60 from Taiwan has demo time limitation on it, but once you enter the sw.unl key, it unlocks the program to work beyond the time limit. Suggest you get anohter version, eg 4.10.20 or 4.10.40, get it unlocked then install the 4.10.60 update.
Old 01-25-2008, 07:02   #958 (permalink)
Member: 668701
I got the malsingmap *gmapsupp.img* in the garmin folder.
Ok, I googled for the Garmin XT base map and here's what I found...
http://www8.garmin.com/support/downl...ls.jsp?id=3645
It's a worldwide basemap. Though I'd share... Cheers!
Will update the status later...
Old 01-25-2008, 07:29   #959 (permalink)
Member: 668701
Ok, abit of an update...
Manage to view Malaysia's detailed map after I get the base map in. Thanks Ozling.
BTW, are you from KL? I'm looking for someone with a BT GPSr that can loan me for a while to test out if it works on the P1i and weather it's feasable for the amount spent on the BT GPSr?
Read someones commented that the software's laggy?
Old 01-25-2008, 10:17   #960 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
Originally Posted by cc3 View Post
Hi BuMobiles,
thank you!
cheer!
you need to generate a new device unlock code,
try formatting memory card, factory reset phone, install garmix xt, generate unlock code (this should work )
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
help with Garmin XT 4.10.60 S60 please?? se1boy GPS devices , Navigators & Maps 22 06-23-2008 05:48
Garmin XT 4.10.80 (taiwan) titan05 Nokia Multimedia 5 03-23-2008 04:27
Garmin XT 4.10.60 S60 deankanonik GPS devices , Navigators & Maps 9 01-09-2008 22:01
Garmin XT 4.10.20 PROBLEM slososk GPS devices , Navigators & Maps 14 12-28-2007 00:41
Page generated in 0.25948 seconds with 10 queries
