GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
01-27-2008, 03:22 | #978 (permalink) |
Major Poster Join Date: Jan 2008
Member: 689101 Status: Offline Thanks Meter: 282 | For whatever reason after a few launches it now recognises the internal gps. Only problem now there is no speech/voice. I looked at the support files on page 50 but the link doesnt work for me. please can someone upload. This is really a long & complicated job to get it working. Once i get it working im going to combine all files together in 1 zip file to make it easier for your next Joe Blogs. Why so many files not in one place makes it complicated. I will also try make new step by step instruction for people like me that found it difficult. Perhaps im not smart enough lol Last edited by almostdone; 01-27-2008 at 03:31. |
01-27-2008, 04:58 | #979 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
01-27-2008, 08:10 | #980 (permalink) | |
Junior Member Join Date: Jan 2008
Member: 684386 Status: Offline Thanks Meter: 1 | Quote:
thanks for the helped. my N70 is working now.... the reason and step was .... must remote all the garmin files, and install 4.10.20 then install 4.10.40 or 4.10.60. if direct install 4.10.60 sure doesn't work! that what I find out. cheers! thank you | |
01-27-2008, 11:45 | #981 (permalink) | ||
Insane Poster Join Date: Dec 2004
Member: 96817 Status: Offline Thanks Meter: 5 | Quote:
Any help or info? | ||
01-27-2008, 19:23 | #983 (permalink) |
Member: 690796 Status: Offline Thanks Meter: 0 | Hi All, For N95 8gb users, specialy those who disconnect often from satelites, try the following: (It works for all GPS app: Garmin, Sygic....) Before start any of your GPS app, go to Tools>connectivity>GPS data, click options>positioning settings, make sure that only "integrated GPS" &"Network based" are checked (do not check "Bluetooth GPS" & " Assisted GPS") After that, go back and click on postion, click option>satelite status, wait till have connection to satellite (sure you have to be in open area) after receiving signals, and without exiting from the GPS data menu, go to your app and start it. I assure to you that it will never disconnect (also it will be better if you open your slide) Hope that this will many problems (IT RESOLVE MINE, AFTER A LOT OF SEARCHING) good luck |
01-27-2008, 19:41 | #986 (permalink) | |
Canada is part of the North America map, use map installer to chop it up and only load Canada instead of the whole thing. | |
01-28-2008, 01:19 | #987 (permalink) | |
Member: 688543 Status: Offline Thanks Meter: 0 | Quote:
hey, thanks for the reply, so if install 4.10.60 with 4.10.20 already there, it should work ? so i have to get it unlocked first sorry, i left out info in the first post, i was running 4.10.20, trying to use it with city navigator north america NT, 1.11gb version. | |
01-28-2008, 01:43 | #988 (permalink) |
Member: 96817 Status: Offline Thanks Meter: 5 | It's only until I had posted that, I realised that I hadnt even created the SW.UNL file. So once that was sorted. It worked. Just a damn shame about certain things. I guess I'm a sucker for TomTom. If they could only hurry up with a release that will utilise the intergral gps... |
01-28-2008, 03:31 | #990 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 433671 Status: Offline Thanks Meter: 118 | Quote:
The unlock codes is the same for the same device ID. If the MMC and hardware remains unchanged, there is no need to recalculate the sw.unl codes again. | |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
help with Garmin XT 4.10.60 S60 please?? | se1boy | GPS devices , Navigators & Maps | 22 | 06-23-2008 05:48 |
Garmin XT 4.10.80 (taiwan) | titan05 | Nokia Multimedia | 5 | 03-23-2008 04:27 |
Garmin XT 4.10.60 S60 | deankanonik | GPS devices , Navigators & Maps | 9 | 01-09-2008 22:01 |
Garmin XT 4.10.20 PROBLEM | slososk | GPS devices , Navigators & Maps | 14 | 12-28-2007 00:41 |
