GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
12-28-2008, 13:45 | #152 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Denmark Age: 57
Member: 385577 Status: Offline Thanks Meter: 656 | Quote:
Here: http://forum.gsmhosting.com/vbb/showthread.php?t=398103 Regards Mike | |
12-29-2008, 07:46 | #156 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Australia
Member: 571765 Status: Offline Thanks Meter: 5 | Hi Mike, I managed to install and crack Garmin XT ver5 now can you tell me if i can use same maps for Aus as of ver 4 ? I did that but my Garmin is unable to find Internal GPS. I have changed the UNL files with codes but still no luck what could be the reason? |
12-29-2008, 08:39 | #157 (permalink) | |
If you have done as stated in the piece of paper you downloaded, it should be OK.... Be patience... It takes some time for the phone to find the satellites the first time..... Please check you saved the file af SW.UNL and not as SW.UNL.TXT... Did you save it in the Garmin folder..? Regards Mike | |
12-29-2008, 09:13 | #158 (permalink) |
Member: 571765 Status: Offline Thanks Meter: 5 | I did same and its not .txt file ... everything is ok but it says "Detailed maps are required" Iam using same maps of ver4 and the name of file is "gmapsupp.img". It also says cannot unlock maps with ID |
12-29-2008, 09:25 | #159 (permalink) | |
You have to unlock tha map so it is fitting to your new device.... Regards Mike | |
12-29-2008, 09:50 | #161 (permalink) |
Member: 385577 Status: Offline Thanks Meter: 656 | Two options: 1) The wrong one but very easy: Look in the "How-to" papers 2) The right one using mapsource: Download the latest version of MapSource from this link http://www8.garmin.com/software/MapSource_6141.exe After installing MapSource install the map using eg. CNEUNT2009Update_ENU.msi - Not the Setup.exe. This will install the map only. After installing the map launch MapSource and unlock the map, use a key generator which you can find here: http://forum.gsmhosting.com/vbb/show....php?p=3850220 Enter your GPS's ID number and mapid in the key generator, and you have the unlock-code. In Mapsource, click Utilities > Manage Map Products Select the Unlock Regions tab, and click Add Enter your 25-character unlock code and then a comment, if desired. Click OK For more info look in the user guide for Mapsource: http://www8.garmin.com/manuals/MapSo...UsersGuide.pdf Then you transfer the part of the map (e.g. Spain) you would like to your GPS…. If you would like to have more maps, e.g. Garmin City Navigator Europe NT 2009 and Garmin City Navigator North America NT 2009 you can combine the maps and transfer them to you GPS. Try it..... Regards Mike |
12-29-2008, 09:55 | #163 (permalink) |
Member: 571765 Status: Offline Thanks Meter: 5 | dam again new problem ... when i start the application it shows bluetooth is currently off please turn it on. When i press ok , it exit the application automatically ... now what is the problem here...? |
12-29-2008, 09:57 | #164 (permalink) | |
Let us all share our maps Requirements for maps to be included in the list: 1) All maps must be MAPSOURCE versions - not gmapsupp.img. 2) The map must be routable, and may not be prepared from a gmapsupp.img map. 3) New / Other maps to be included in the list must be in a better resolution than the existing maps. If you have a map, or have knowledge of a map that meets these requirements, please post the link here..... What is the advantage of using Mapsource? In this way you can combine several different maps, and transfer them to your GPS as a single map. Fell free to download the maps you need..... If you find this post useful, please say thanks you..... AdriaROUTE 2.20 - Mapid: 708 Download SCG Route 1.90 - Mapid: 929 Download Slovakia Roads v6 - Mapid: 1315 Download R.O.AD.2008 v3.01 (Roads of Romania) - Mapid: 1189 Download, part 1 Download, part 2 Garmin Navcity Turkey 2008.07 - Mapid: 848 Download, part 1 (Password: tom1807) Download, part 2 (Password: tom1807) Mirror, part 1 Mirror, part 2 Garmin Mapsource World Map 4.06 Download OFRM Bulgaria v4.70 - Mapid: 5028 Download NaviGuide Hungary 5.1 NT - Mapid: 709 Download CarteBlanche Ukraine 3.50 - Mapid: 575 Download Venezuela Venrut 4.1 - Free map Download Mapear V7.00-Mapas Electronicos Argentinos - Mapid: 900 Download Mirror Philippine Islands - Free map Download Laos/Vietnam - Free map Download Samoa - Free map Download Indonesia 0.66 - Free map Download Greece - Free map Download Cyprus - Free map Download Peru 0.49 (20/12/08) - Free map Download Garmin City Navigator Europe NT 2009 - Mapid: 378 Download (Torrent) Garmin City Navigator North America NT 2009 - Mapid: 325 Download (Torrent) Garmin Chile Streets 2007 - Mapid: 724 Download (Torrent) Garmin City Navigator Australia NT 2009 - Mapid: 358 Download (Torrent) Garmin City Navigator Middle East NT 2008 - Mapid: 329 Download Mirror Garmin City Navigator Mexico NT 2008 - Mapid: 278 Download, part 1 Download, part 2 Download, part 3 Garmin City Navigator NT New Zealand 2009 - Mapid: 499 Download GARMAP Southern Africa Streetmaps, Topo & Rec, March 2008 Mirror (Torrent) GARMAP Indian Ocean Islands Streetmaps Version 1 Mauritius - Mapid: 1148 Download Mirror (Torrent) GARMAP East Africa Street Maps Version 1 - Mapid: 1095 Download Mirror (Torrent) GARMAP Nigeria Streetmaps, Topo & Rec Version 2 - Mapid: 807 Download Mirror (Torrent) GARMAP Southern Africa Streetmaps, March 2008 - Mapid: 1214 Download Mirror (Torrent) Roads of Russia with Routing 4.03 - Mapid: 1120 Download (Torrent) Mirror, part 1 Mirror, part 2 Mirror, part 3 Mirror, part 4 Mirror, part 5 Mirror, part 6 Moldova 20.12.2008 - Free map (Map updated) Download Garmin Polska GPMapa 2008.3 - Mapid: 1326 Download Garmin EU SpeedCams 2008 update 11 Download MapSource Taiwan City Navigator ver 8.51 English - Mapid: 287 Download Garmin Iceland GPS Kort v3.5 - Mapid: 830 Download (Torrent) Czech Republic (ATLAS TJEKKISKE v7 NT) - Mapid: 579 Download (Torrent) Map of Sri Lanka (Sri Lanka Route) - Free map Download (Torrent) TrackSource Brasil 5.12 - Free map Download Lithuania Topo 1.06 - Mapid: 857 Download (Torrent) GM-MySin Installer v2.30 (Malaysia and Singapore) - Mapid: 5088 Download GM-Borneo Installer v2.30 - Mapid: 5099 Download | |
12-29-2008, 09:59 | #165 (permalink) | |
Maybe you should try to reinstall? Regards Mike | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f491/garmin-xt-maps-mapsource-version-632595/ | ||||
Posted By | For | Type | Date | |
What is GARMIN XT V5 MIDDLE EAST? | This thread | Refback | 06-29-2013 08:06 |
malaysia map for garmin xt | carrotboy88 | GPS devices , Navigators & Maps | 1 | 01-19-2012 08:18 |
Garmin XT Canada Map | jati_grewal | GPS devices , Navigators & Maps | 2 | 07-18-2009 13:10 |
maps for garmin xt | billyprepo | GPS devices , Navigators & Maps | 1 | 03-11-2009 10:33 |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
Garmin XT Canada Maps 2009 | s3lekta | Nokia Multimedia | 0 | 09-21-2008 19:45 |
