Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 10-05-2009, 00:16   #1 (permalink)
Member: 1133216
Garmin nuvi and windows 7
Hi,
Recently I formated my Garmin nuvi 205w with windows 7 and since than
I cannot turn it on, its keep restarting, it just makes a beep and displays
the garmin logo and then it turns of again for few seconds and turns on
and goes so forever.
Before, I formated it many times with windows xp and all was fine.
Any ideas??
Old 10-05-2009, 20:01   #2 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
Originally Posted by nticaric View Post
Hi,
Any ideas??
Try formatting it as fat32 not as ntfs
Old 10-11-2009, 13:52   #3 (permalink)
Member: 1133216
The device is not recognized by windows so i cannot format it anymore
Old 11-26-2009, 18:38   #4 (permalink)
Member: 984920
Thanks Meter: 5
You screwed it dude...
If you have W7 installed on your PC (same as I do) you can format in fat mode, but no way you can introduce the command.com or the 32bit OS, as W7 has not it anymore...
The way I can think about:
- get a Virtual Machine loader (Sun VirtualBox works for me): http://www.virtualbox.org/wiki/Downloads
- Install the VirtualBox software (won't damage your system, guarantee)
- Downolad from somewhere out there an XP IMAGE file (an XP converted to image, like nero or WinIso) (just google out "windows xp iso image" )
- Install XP (mount XP image) inside the virtual machine, & install the XP as if you were installing it on a brand new hard disk)
- copy all Nuvi CD & install INSIDE the Virtual machine Disk (you will see it as Virtual Disk C)
- proceed as you did before when XP was your system, format the Nuvi, & all over...
Good luck
Carlos
(Windows Seven Ultimate + Garmin Nuvi 710)
Old 11-26-2009, 18:50   #5 (permalink)
Member: 984920
Thanks Meter: 5
sorry, double enter.. please remove post
ATF and Windows 7 32-bit / Windows 7 64-bit frozenice Advance-Box 24 05-22-2012 09:41
Spiderman and Windows 7 64 bit? dual29 SpiderMan 22 12-06-2011 13:37
Spiderman and Windows 7 Tested 100% BesTCooL SpiderMan 8 04-14-2010 22:20
Polar box2 need support for windows vista and windows 7 [USER REQUEST] abuscoking PolarBox 3 1 01-08-2010 16:17
When UST support Windows Vista and Windows 7 huyanten UST Pro II 4 10-26-2009 09:36
Page generated in 0.14389 seconds with 9 queries
