GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
04-01-2016, 17:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1925139 Status: Offline Thanks Meter: 76 | Map & Guide Desktop Europe City 2015 (v21.0) .. Opis Uploadu: Code: Weight: 11.3 GB Contents: .iso, crack, installation instructions (in the middle of series) Compression: rar Language: Multilanguage / ENG Data recovery: 5% No password PTV Map & Guide posiada szeroki asortyment oferuje więcej niż tylko planowania trasy. PTV Map&Guide Desktop possesses an extensive range of additional functions, which offer more than just route planning. For example, you can display your clients' addresses or put together personal routes. Plus road closures: Use the road editor to change individual road closures on the map, to close or open specific roads (e. g. depot entrances that are blocked for other road users). API: You can operate PTV Map&Guide desktop via your own interface (API) and, in turn, integrate customized functions into your software. Display and classification of client data: In PTV Map&Guide you can import client data in different formats. The addresses can be categorised (e.g. as A, B and C clients) and visualised with different symbols or colours on the map. Connection to Teleroute's freight exchange: Teleroute's freight exchange, which is now integrated into PTV Map&Guide, allows you to find additional freight along a route, for a return trip or at selectable stop-off points on your route, to book loads via the Teleroute freight exchange and then integrate them into your standard PTV Map&Guide itinerary. PTV Map&Guide calculates the rise in costs incurred by transporting additional freight. By comparing these costs with the revenue from the transport order, you can easily see whether the order is profitable. Add-on call center: The PTV Map&Guide additional module add-on call center helps you select the optimum service provider. And therefore avoid unnecessary costs. The software solution provides you with reliable localization and all the information you require about the location in a matter of seconds. Program = Application DVD DVD1, DVD2 and DVD3 = Europe City Maps Unrar the files • Burn or mount the Image with your favorite Tool • Start Setup and install • Follow instructions from \CYGiSO\readme.txt on Program DVD • Done Microsoft Windows XP, Vista, 7 or 8 Code: http://sharehost.eu/file/+eXHez75SZ-Hs80XGudCSQ==/Map-&-Guide-Desktop-Europe-City-2015-v21.0-Crack-Serial-.part1.rar http://sharehost.eu/file/czEyPXSEDDT9fVOSEjDmhA==/Map-&-Guide-Desktop-Europe-City-2015-v21.0-Crack-Serial-.part2.rar http://sharehost.eu/file/0UGI7NXH4aWVS4ElUlE8Sg==/Map-&-Guide-Desktop-Europe-City-2015-v21.0-Crack-Serial-.part3.rar http://sharehost.eu/file/SrYnLtezz4DOhHeS3L3KYw==/Map-&-Guide-Desktop-Europe-City-2015-v21.0-Crack-Serial-.part4.rar http://sharehost.eu/file/DYnMrY-nOeuP9sCemrl6CA==/Map-&-Guide-Desktop-Europe-City-2015-v21.0-Crack-Serial-.part5.rar http://sharehost.eu/file/lPXX+E6srGbfuuGtDaTXfA==/Map-&-Guide-Desktop-Europe-City-2015-v21.0-Crack-Serial-.part6.rar |
The Following User Says Thank You to studzina0812 For This Useful Post: |
