Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 08-08-2007, 23:28   #46 (permalink)
Member: 442169
no not tried the 7.3.486, so cant really say, but no difference between the mobile 7.0 and this one, except the internal gps can be used on my n94, regards
Old 08-09-2007, 08:18   #47 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 271
i need an more clear answer about 6110.
can 6110 works with more maps (for free) by pressing the NAVIGATOR special KEY ??
Old 08-09-2007, 10:07   #48 (permalink)
Member: 61131
Thanks Meter: 3
No, not with the included version (on 6110 Navigator).
BUT, for aditional maps install from version 7.3.486 and upwards,
start it via programs since it's a separate program...
On that version you get free maps, trafic, etc (see other posts).
/Niska
Old 08-09-2007, 21:41   #49 (permalink)
Member: 460161
I read the entire post.. and this got brought up a couple times but was never really answered..
What does it mean by unpatched?? I understand the previous version (486) you need a cert file and to sign the app before installing.
Can the same method be applied to this version? or does it need to be "patched" to a unsigned version first?
Thanks
Old 08-11-2007, 16:53   #50 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
a little treat for you All!
Route66 mobile v7.3.545 multilanguage unsigned cracked s60v3
1, Sign the App with a valid Certificate
2, Copy the Maps into the Folder called \System\Apps\Route 66\Maps
3, Install the App
4, Select Activate Via Internet
5, Enter any 16 digit number works ok!
6, Enjoy!
http://www.badongo.com/file/4014123
Old 08-11-2007, 17:01   #51 (permalink)
Member: 331838
Thanks Meter: 4
I can confirm that it actually works on the N95. A job well done
I believe trickydave was the first to post this? Anyway, now also available in the usual RS folder here http://rapidshare.com/users/2UG51R
Old 08-11-2007, 17:03   #52 (permalink)
Member: 96817
Thanks Meter: 5
3, Install the App
6, Enjoy!
Another question, but how are you going to do step 2.
If you havent done step 3 before..
Old 08-11-2007, 22:01   #53 (permalink)
Member: 354420
How do you sign the app ?
cheers
Old 08-11-2007, 22:13   #54 (permalink)
Member: 128748
Thanks Meter: 2
cheers bumobiles used the maps from this version in the older r66 may as well update the app lol
Old 08-12-2007, 03:40   #55 (permalink)
Member: 271782
how to we sign route66 for N95 given that www.symbiansigned.com is not allowing new registarations?
why is there a fully cracked version (no signing needed) of the newer Route66.Mobile7.3.520, but not a proper cracked Route66.Mobile.v7.3.545.
please can any one either post or mail me link to a fully cracked version of Route66.Mobile.v7.3.545. ]
or a way of signing a sis without needing www.symbiansigned.com,
or a username and password for www.symbiansigned.com is not
thanx [email protected]
Old 08-25-2007, 04:30   #56 (permalink)
Member: 572625
the file worked great for me
I installed the unsigned 95 545 version and used my activation that i used for a previous 520 version
It is finally working great with the internal GPS
Thanks for all your help as i have been tryng to get this to work for ages
Old 08-26-2007, 20:57   #57 (permalink)
Member: 562482
what is the activation code ?
Old 08-26-2007, 21:13   #58 (permalink)
Member: 61131
Thanks Meter: 3
the order of step 2 and 3 isn't important.
It will still work aslong as you do both.
Connect the phone in Data transfer mode or memory card in an external reader, and make sure windows see hidden files and folders.
Search the forum there are threads swhere you get cert or
your applications get signed.
There are cracked versions available (but 545 is higer then 520)
Any 16 digits or letters on the cracked versions.
Enter it under registration over internet =)
Old 08-26-2007, 21:40   #59 (permalink)
Member: 562482
Originally Posted by a701user View Post
Available on usenet. Zipped .nzb attached. Perhaps someone with high speed will up this to rs or whatever.
This is the new build that runs on N95, but it need to be patched first.
The maps can be used on older versions too. They are dated 01-22-07 and include:
Benelux -108MB
Britain -220MB
DACH -383MB
EasternEurope -181MB
EuropeMR -126MB
France -275MB
Greece -9.5MB
Iberia -234MB
Italy -213MB
Scandinavia -286MB
this topic should be removed...
what is unpatched ? if there is no patch for it what good is this ?
and what is this file for ? where does this file needs to be placed ?
i downloaded the software but its asking for an activation key
the software seems like its signed..so what does it mean by unpacthed ? and how / where do u get the key ? can u even get it ?
Old 08-26-2007, 21:42   #60 (permalink)
Member: 562482
Here's the soft itself, not including the maps.
http://rapidshare.com/files/45347059/r73545n95.rar
and am installing this right ? click the setup file ?
still needs activation key.. any 16 digit or leter doesnt work
TomTom v6-7 and Route 66 v6 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 4688 07-04-2013 17:57
what is route 66 and tom tom for N95??/ shengster Nokia Multimedia 4 01-22-2008 00:16
NEW Route 66 7 mobile supports internal GPS ronaldo-9 GPS devices , Navigators & Maps 18 12-18-2007 03:50
Difference between Route66 versions 7.3.486 and 7.3.545? fjaff Nokia Multimedia 0 10-26-2007 23:09
Route 66 Wms Latest Uk Maps ??? markcoopz GPS devices , Navigators & Maps 0 03-18-2007 13:34
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.31961 seconds with 9 queries
