E:\Great_Britain>key2.exe great_britain.mid Enter Device ID:ANCSA ASHCE Activation code: E7EP5 E67UV PXUVJ Key doesn't work for me. Can anyone help? Nokia N95 Also does anyone have a different key gen? I see a lot people have same problem as me. Thanks |
Try the device ID without the space... |
I did try but it gave me exactly the same activation code. |
IF IT IS JUST GREAT BRITAIN MAP ON ITS OWN I GOT BASED ON MY OLD COPY. ID=Great_Britain.pna 638525234 650 build=1111 id=46030 PALM / SYMBIAN E7EP5 E67UV PXUVJ POCKET L3NV3 KVESC BWCHJ ONE / GO BJN2Z S33N7 74QVH |
IF IT IS JUST GREAT BRITAIN MAP ON ITS OWN I GOT BASED ON MY OLD COPY. ID=Great_Britain.pna 638525234 650 build=1111 id=46030 PALM / SYMBIAN E7EP5 E67UV PXUVJ POCKET L3NV3 KVESC BWCHJ ONE / GO BJN2Z S33N7 74QVH TRY USING UNITED KINGDOM PLUS IRELAND AT http://rapidshare.com/files/17237080...land.part1.rar http://rapidshare.com/files/17237215...land.part2.rar ID=United_Kingdom_and_Republic_of_Ireland.pna 1555242764 660 build=1219 CODE ANCSA ASHCE ACTIVATION CODE V6JK9 24DV2 FA2DS |
Thanks for the help but I've downloaded the new maps and get the same problem. One quick question I have both .mid and .pna file for Great_Britain v6.50 build 1111. Should i use the keygen for the .mid file or .pna? It generates a different code. SCREEN DUMP E:\Great_Britain>key great_britain.pna Flag 0x80 Need activated 'Primary' map to activate this one Enter Device ID:ANSCA ASHCE Activation code (Palm/Symbian): MEDJC CYDJW BVCMJ Activation code (Pocket): 296MC Q2LVR LC4ZJ Activation code (One/Go): XJBET 6FHEN 7A4M5 |
Need activated 'Primary' map to activate this one So you activate the guam map first, then switch to other map & activate do not delete the guam after you have activated!!!!. |
I'm really sorry but I'm confused. |
http://www.badongo.com/file/3237956 |
'Primary' map Enter Device ID:ANSCAASHCE Activation code (Palm/Symbian): NWFSU 4VDRU TYW6A Activation code (Pocket): 5WH63 WMVWZ MDLAA Activation code (One/Go): SA7Y4 987AY GA264 |
I don't knw what happened but it's working now... I removed the memory card, did a hard reset and re-inserted the memory card. It installed the tomtom apps by itself from the data on the memory card. Lanched tomtom and I didn't enter any codes. It did not ask for activation either. Just select which map I wanted and now working fine. :D STRANGE. The reason I did a hard reset because tomtom stopped working. |
can anyone tell me a key for usa map i have treo 700p OR CAN ANYONE POST A KEYGEN ....my id is NF6TA 6V55A THANK U |
TomTom.Mobile..S60v3.SymbianOS9.1.Cracked-BiNPDA Simple install with guam map to test, just unpack open folder & copy to mem/card!!!! insert card back to fone & run__sis!!! http://www.badongo.com/file/3102919 |
hello everybody, got the problem.... cant get voices work out on tom tom 6.020... can some1 plz help me... thank you very much.. |
