GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
06-10-2019, 19:53 | #1 (permalink) |
Junior Member Join Date: Nov 2017 Location: france
Member: 2782282 Status: Offline Thanks Meter: 0 | old version TTHOME file profile.dll i am looking for a TOMTOM HOME profile.dll . I am quite sure that i need this file to use this TTH2 function's . Thanks . I have a message from fast activate: TomTomHome Profile.DLL not found and the button handle (manipulate) my device is grey... |
06-11-2019, 00:12 | #2 (permalink) |
Moderator Join Date: May 2009 Location: United States
Member: 1032904 Status: Offline Thanks Meter: 1,270 | Run TT Home "operate my device". If TT Home wants to download a file, do so, then patch TT Home. |
The Following User Says Thank You to jmermel For This Useful Post: |
08-18-2019, 11:52 | #3 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1406087 Status: Offline Thanks Meter: 26 | Hi jmermel, I have the exact same problem as gil77000, when using "FastActivate" the message "TomTomHome Profile.DLL not found" appears. I'm new to all of this updating stuff on TomTom devices and would really appreciate any of your knowledge you could pass on to help me out. Many thanks. gpz900ra7 |
08-18-2019, 13:04 | #4 (permalink) |
Member: 1032904 Status: Offline Thanks Meter: 1,270 | Instructions: 1. Plug your tomtom device with the USB to your PC or use card reader 2. Copy "FastActivate.exe" to your TomTom device internal or SD-Card ROOT directory (recommended) or desktop or any other place 3. Run "FastActivate.exe" 4. Use menu buttons what you need see menu items help. 5. Done... Menu items: 1. Update meta.txt Update latest meta.txt. (if servers are not down) You need to allow wget.exe in your firewall if asked. If you have a new meta code which is not in the integrated or updated meta.txt (See in program for date of current integrated meta.txt) then you must put all new meta codes in a file named META.TXT and copy it to the Device/SD-Card ROOT Directory or keep it in the same directory as FastActivate.exe. 2. Patch Maps, Voices, Speedcams and Fuel Prices Patch ALL these in your device. If you get a ".dct ERROR" message, it usually means the meta has not been released. 3. Patch Navcore (ttsystem or PNDNavigator) Patch Your Navcore with this which is needed to use patched maps. Wait and it will tell you when done. 4. Patch TomTom HOME This works automatically and there is no need to search for any files, just wait and it will tell you when done. If you use this you first need to use TomTom HOME "Operate my Device" option; this will download your profile files; then close HOME and patch it. 5. RunMeForCode (Create a meta/****fish code from genuine map) You can create meta code with this button...you have to be the original owner of the map. Remember... meta data does NOT contain any personal information from you or your device. It is safe to share. 6. Update QuickGPSfix (Fix your GPS position) Your TomTom device uses the signals of at least 4 satellites to find out where you are. To start navigating, it needs to know exactly where each satellite is. So start your journey faster with TomTom QuickGPSfix button 7. My Device Info This is just info from your device which others need if you ask for help (on most forums). 8. Android Activation Use this button on Android device with patched .apk. Notes: Note 1: If you get trouble running the .exe then "right click and run as administrator" If you use Wince and mapshare p a t c h copy ttnavigator.bif to ttgo.ori Note 2: If You use special characters in windows user name program may halt. eg. &, <, >, |, ^ Note 3: If you are doing a fresh install on internal memory of navcore and map then you will need to restart the unit once after the installation of navcore Before you try and patch the map because your unit will then generate the needed ttgo.bif file for the keygen to read. Also if you are installing to a sd card rather than the internal memory the same applies you will need to insert the sd card into the tomtom device and reboot before you patch the map so it generates the needed ttgo.bif file. Note 4: Program works with TomTom PC emulator. Fastactivate April 2019. Thanks to pietu Last edited by jmermel; 08-18-2019 at 21:27. |
