Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 07-04-2013, 21:05   #1 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 432
Arrow FastActivate New version hire 06-06-2013
FastActivate New version hire Enjoyyyyyy
New map Active V910.xxxx ( If meta Code Available )
If U like My Post press thanks
Instructions:
1. Plug your tomtom device with the USB to your PC or use card reader
2. Copy "FastActivate.exe" to your TomTom device internal or SD-Card ROOT directory (recommended) or desktop or any other place
3. Run "FastActivate.exe"
4. Use menu buttons what you need see menu items help.
5. Done..
Menu items:
1. Update meta.txt
Update latest meta.txt. (if servers are not down) You need to allow wget.exe in your firewall if asked.
If you have a new meta code which is not in the integrated or updated meta.txt (See in program for date of current integrated meta.txt) then you must put all new meta codes in a file named META.TXT and copy it to the Device/SD-Card ROOT Directory or keep it in the same directory as FastActivate.exe.
2. Patch Maps, Voices, Speedcams and Fuel Prices
Patch ALL these in your device.
If you get a ".dct ERROR" message, it usually means the meta has not been released.
3. Patch Navcore (ttsystem or PNDNavigator)
Patch Your Navcore with this which is needed to use patched maps. Wait and it will tell you when done.
4. Patch TomTom HOME
This works automatically and there is no need to search for any files, just wait and it will tell you when done.
If you use this you first need to use TomTom HOME "Operate my Device" option; this will download your profile files; then close HOME and patch it.
5. RunMeForCode (Create a meta/****fish code from genuine map)
You can create meta code with this button...you have to be the original owner of the map.
Remember... meta data does NOT contain any personal information from you or your device. It is safe to share.
6. Update QuickGPSfix (Fix your GPS position)
Your TomTom device uses the signals of at least 4 satellites to find out where you are. To start navigating, it needs to know exactly where each satellite is.
So start your journey faster with TomTom QuickGPSfix button
7. My Device Info
This is just info from your device which others need if you ask for help
DownLoad Hire
http://www.mediafire.com/download/2q...02-06-2013.rar
password GSM FORUM
The Following 4 Users Say Thank You to bux_harun For This Useful Post:
Page generated in 0.12783 seconds with 8 queries
