Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 02-16-2019, 10:37   #1 (permalink)
Member: 1529452
Sonork: 100.1637909
Thanks Meter: 47
oppo f7 new security not don
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM17
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6771
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CA00
>>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000D0A303030 -> 53411M
Flash ID: 0x2031303035203030
Flash Name: UNKNOWN
Flash symbol: 05 000
>>> Reading Mobile Map Data...Fail
The Following 2 Users Say Thank You to sarfraj.k For This Useful Post:
Old 02-17-2019, 00:52   #2 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
MediaTek USB Port
CPU_NAME: MT6771
Flash Name: UNKNOWN
this logs wrong TP using 100% tested me
how to work?
first connect TP to Gnd
press start
press vol up
after run fast cut the TP wire
then fast connect battery
easy done 1000% tested me.
The Following 7 Users Say Thank You to ernie78™ For This Useful Post:
Old 02-17-2019, 05:04   #3 (permalink)
Member: 1529452
Sonork: 100.1637909
Thanks Meter: 47
how to work?
press start
press vol up
Same error
Map data fail
Old 02-17-2019, 05:31   #4 (permalink)
Member: 239651
Who can teach me how to unlock pattern lock and reset oppo f7 youth by met?
Can anyone and friends can teach me how to unlock by mrt...
Old 02-17-2019, 06:24   #5 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
make sure you select oppo check box
Old 02-17-2019, 06:24   #6 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
Same error
Map data fail
because need TP carefully
try and try until done
Old 02-25-2019, 14:41   #7 (permalink)
Member: 286307
Thanks Meter: 6
f7 cph 1819 new boot
Get Mobile Port is: COM31
MediaTek USB Port_V1632
CPU_NAME: MT6771
Flash Size: 0x0000000E8F800000 -> 59640M
Flash ID: 0x90014A4843473861
Flash Name: Hynix_Unknow
Flash symbol: HCG8a4
>>> Reading Mobile Map Data...Success
>>>>Writeing Mobile data userdata ...
Corresponding operation completed!!!
Old 02-25-2019, 17:32   #8 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Same error
Map data fail
You are not perfect to handle it!
Mrt perfect done !
Old 03-02-2019, 12:20   #9 (permalink)
Member: 286307
Thanks Meter: 6
matta f7
Get Mobile Port is: COM62
CPU_NAME: MT6771
Flash ID: 0x150100444836444D
Flash Name: Samsung_Unknow
Flash symbol: DH6DMB
Old 04-17-2019, 09:31   #10 (permalink)
Member: 1822938
Sonork: 100.1656339
Thanks Meter: 63
MediaTek USB Port
CPU_NAME: MT6771
Flash Name: UNKNOWN
For who come after this error.
do with battery, dont format whitout battery => fault
Remove testpoint immediately after this part
then you are done with it
The Following 2 Users Say Thank You to goldenfish125 For This Useful Post:
Old 04-27-2019, 15:59   #11 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 67
Get Mobile Port is: COM37
MediaTek USB Port
CPU_NAME: MT6771
Flash Size: 0x0000001D1EC00000 -> 119276M
Flash ID: 0x150100335636434D
Flash symbol: 3V6CMB
The Following User Says Thank You to dre2 For This Useful Post:
Old 05-05-2019, 12:35   #12 (permalink)
ma341032's Avatar
Member: 1370803
Sonork: ma341032
Thanks Meter: 36
how to work?
press start
press vol up
Get Mobile Port is: COM149
MediaTek USB Port
CPU_NAME: MT6771
The Following 3 Users Say Thank You to ma341032 For This Useful Post:
Page generated in 0.21986 seconds with 9 queries
