Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 07-31-2019, 05:17   #1 (permalink)
Member: 1137967
Thanks Meter: 34
oppo a3s cph1853 connection error aetool
hello aetool team
please guide me how to connet a3s cph 1853 with aetool
please give me the pinout diagram
are vccq and vcc pinouts required or not
Old 07-31-2019, 06:43   #2 (permalink)
Member: 1137967
Thanks Meter: 34
is it supported in aetool or not
Old 07-31-2019, 07:07   #3 (permalink)
Member: 2878108
use only 4 line > GND , CMD ,DAT0 , CLK
and connect usb cable
Old 07-31-2019, 07:22   #4 (permalink)
Member: 1137967
Thanks Meter: 34
>>>>Searching EMMC Devices....
MAE ToolSN 0626 TS37
>>>>Testing EMMC disk read status....
Reading EMMC Capacity Info...
Capacity Size:15634268160Byte/14910MB/14.91GB;(Hex:0x03A3E00000)
Wrong EMMC disk data; this may be an empty Flash IC!!!
Old 07-31-2019, 07:30   #5 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,874
Originally Posted by vicky matharu View Post
>>>>searching emmc devices....
Mae toolsn 0626 ts37
>>>>testing emmc disk read status....
Reading emmc capacity info...
Capacity size:15634268160byte/14910mb/14.91gb;(hex:0x03a3e00000)
wrong emmc disk data; this may be an empty flash ic!!!
connect gnd to ae tool short and strong wire
Old 07-31-2019, 07:31   #6 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,104
connect vcc no need connect vccq off ae tool power switch connnet charger without battery ae tool red light and blu light will come just make wipe
Old 07-31-2019, 07:33   #7 (permalink)
Member: 1798740
Sonork: 1621776
Thanks Meter: 12
i have same problem CPH1853
but CPH1803 easy to connect
Old 07-31-2019, 07:52   #8 (permalink)
Member: 1137967
Thanks Meter: 34
i tried but not working
Old 07-31-2019, 08:04   #9 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,874
If you use poor wire then change it thicknesses need good
Old 07-31-2019, 08:07   #10 (permalink)
Member: 1137967
Thanks Meter: 34
i am using good thick wire
Old 07-31-2019, 08:11   #11 (permalink)
Member: 1137967
Thanks Meter: 34
i want to ask that do i need to solder vcc and vccq
Page generated in 0.30538 seconds with 7 queries
