08-02-2017, 07:52 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | xiomi note qaulcomm phone can not flash with flashing tool phone is fastboot mode already Last edited by salim5566; 08-02-2017 at 08:09. |
08-02-2017, 09:23 | #2 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | The phone is bootloader locked! You can't flash in fastboot mode, you must be in edl mode to flash 1.Turn your phone off 2.Hold volume+ and volume- together and insert cable then the phone will be in edl mode then you can flash with mi flash tool. |
08-02-2017, 23:53 | #4 (permalink) |
Member: 792851 Status: Offline Thanks Meter: 136 | thanks for reply but some how i can not put phone in EDL mode i try what u say but soon as i plug the cable in to the phone phone turn on i open phone disconnect battery and try as well doing same thing.is there any other way i can do? |
08-04-2017, 13:52 | #5 (permalink) |
Junior Member Join Date: Aug 2011 Location: colombia Age: 32
Member: 1639972 Status: Offline Sonork: 1669340 Thanks Meter: 0 | I spend the same with this module mount the file but it does not start flas and tried with several models but even so I see they do not correct that problem |
08-05-2017, 01:24 | #6 (permalink) | |
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
from MRT support put phone in hs usb mode (EDL mode) then open software click on refresh then select file and strat i fix my phone use xiao mi flasher | |
