04-03-2018, 08:45 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | Vivo x20 pluc error unlock lock screen frp ???? [ SOLVED] >>>Try connect to mobile...Success CPU_SN: 0x08679E93 MSM_ID: 0x0008C0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Fail Download Boot timeout;Please try into 9008 devices again First:You need Into Mobile To Bootloader model(Fastboot model)!!! Connect your Mobile to Computer!!! Make sure the android driver has be install!!! Searching Android Mobile... Get the Android Deivers Mobile Info: INFO Device style: PD1710_A_1.16.12 fingerprint.abbr=7.1.1/NMF2 Try Unlock Bootload with algorithm 1 algorithm 1 Info: FAIL unclock fail. Try Unlock Bootload with algorithm 2 algorithm 2 Info: FAIL check Signature Fail rebooting... finished. total time: 0.001s vivo X20 plus is suported ???? |
04-03-2018, 10:01 | #2 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | done >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x08679E93 MSM_ID: 0x0008C0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>正在切换到读写模式Success Flasy type: UFS CPU 类型: MSM8996 >>>>正在读取手机分区数据...Success 正在清除手机锁数据... 清除完成后会导致手机的用户数据丢失... 格式化地址:ADD:0x0181400000 Size:0x0D0E3FBE00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal done thanks mrt |
The Following User Says Thank You to gsmiulian For This Useful Post: |
