08-22-2013, 06:22 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: pokhara,nepal
Member: 1314041 Status: Offline Thanks Meter: 43 | Super doctor 3 working with m9100 VCC Pin: GND Pin: Signal Pin:5, 9, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:5 RXD:9 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT6225 Hardware Version:8A05 Software Version:8A00 >>> Downloading First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x02000000 -> 32M Flash ID:0x00EC227E22632260 Flash Name:NOR_KAL5563CAM ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 Formatting Start Adress(Hex): 0x01C00000 Size(Hex): 0x00400000 >>> Formatting... All Done... |
The Following User Says Thank You to rudradeb For This Useful Post: |
08-22-2013, 06:24 | #2 (permalink) |
Member: 1314041 Status: Offline Thanks Meter: 43 | Super doctor 3 working with m9100 >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:5, 9, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:5 RXD:9 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT6225 Hardware Version:8A05 Software Version:8A00 >>> Trying to Connect Mobile with Tracker Mode... Mobile is in TRACKER MODE , you can release Power key now ... Password:FFFF Password:0000 Password:0000 Password:0005 Password:0010 Password:0000 Password:0000 Password:0010 Password:0010 Mobile Reset Done... |
08-22-2013, 06:25 | #3 (permalink) |
Member: 1314041 Status: Offline Thanks Meter: 43 | Super doctor 3 working with m9100 change imei Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=5 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 IMEI=358688000000158 Rebulid IMEI1=355739043101650 Rebulid IMEI2=355739043101651 |
08-22-2013, 06:27 | #4 (permalink) |
Member: 1314041 Status: Offline Thanks Meter: 43 | SUPER DOCTOR 3 WORKING WITH M9100 fixing informality software... Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=5 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... fixing informality software... Done. |
09-16-2013, 16:32 | #5 (permalink) |
Member: 1314041 Status: Offline Thanks Meter: 43 | flash file backup x205 using super doctor 3 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A08, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 007F227E22102201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: R13_MMX_SW_0.15 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: F:\china flash file\micromax\x205 All Done. |
09-16-2013, 16:36 | #6 (permalink) |
Member: 1314041 Status: Offline Thanks Meter: 43 | x205 dead repair superdoctor 3 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A08, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 007F227E22102201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: R13_MMX_SW_0.15 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00700000, size=0x00100000 All Done |
09-16-2013, 16:59 | #7 (permalink) |
Member: 1314041 Status: Offline Thanks Meter: 43 | Micromax x456 dead repair >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:5, 6, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:5 RXD:6 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT625A Tip:This Mobile Support USB Flash... Hardware Version:CA01 Software Version:0001 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x01000000 -> 16M Flash ID:0x00C2002500380000 Flash Name:SF_MX25U12835FZNI_10G ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 Formatting Start Adress(Hex): 0x00E60000 Size(Hex): 0x001A0000 >>> Formatting... All Done... |
