Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 10-24-2016, 09:23   #1 (permalink)
Rex
Member: 3468
Thanks Meter: 299
Pro 5 Bootloop After Remove Password [SOLVED]
Hi,
After remove password bootloop, how to flash firmware? write flash option is not highlight.
Old 10-24-2016, 09:49   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,867
What mrt ver ? Post screenshot
Old 10-24-2016, 09:53   #3 (permalink)
Rex
Member: 3468
Thanks Meter: 299
ver. 1.28
Searching Android Mobile...
Get the Android Deivers
Mobile SN Info: 86164B015FB2
>>>>Trying Connect to Service verification data...
Checking Bootload Infoverify success Success
>>>>Erasing Userdata...
Creating Userdata Block map data...
Some set after unlock need into recovery mode
in the Recovery,hold vol+ 5 times then hold vol- 5 times
Clear the data,after reboot your phone,then can working normal
Corresponding operation completed!!!
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
Old 10-24-2016, 09:55   #4 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,867
Flash it and use previous version
Maybe have bugs in new version
Old 10-24-2016, 09:57   #5 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,867
And post screenshot not just logs
If u understand do what i said
Old 10-24-2016, 09:59   #6 (permalink)
Rex
Member: 3468
Thanks Meter: 299
How to flash? write flash option is not highlight.
Old 10-24-2016, 11:00   #7 (permalink)
zhulianqi's Avatar
Member: 812359
Sonork: 100.1597111
Thanks Meter: 6,786
read it,it aleady tell you how to make it alive
Old 10-25-2016, 12:13   #8 (permalink)
Rex
Member: 3468
Thanks Meter: 299
Problem solved..
phone back to normal
Mobile SN Info: 861F4B015FB2
Now Change Mobile SN Info...
SN Info has Move to 861H4B015FB2 Success...
>>>>Flashing Facotry Frimware...
Writeing Block proinfo...Success
Writeing Block bootimg...Success
Writeing Block recovery...Success
Writeing Block ldfw...Success
Writeing Block bootloader...Success
Writeing Block system...Success
Writeing Block userdata...Success
Writeing Block custom...Success
Writeing Block dtb...Success
Writeing Block bootlogo...Success
Try Get Recovery auth...
Setting Recovery Auth Success...
Mobile will reboot;reboot to factory firmware model
Waiting it reboot done,power off
after power off,you need let the mobile into Recovery
and update your device with update.zip
The Following User Says Thank You to Rex For This Useful Post:
Old 11-04-2016, 10:30   #9 (permalink)
GSM Road Runner's Avatar
Member: 107839
Sonork: 100.1592822
Thanks Meter: 70
Can someone pls upload firmware to any normal server pls??
b.r
Old 11-04-2016, 15:40   #10 (permalink)
Member: 107839
Sonork: 100.1592822
Thanks Meter: 70
MRT1.30
Mobile SN Info: 86172B03B64C
SN Info has Move to 86192B03B64C Success...
Open File Fail,Software Has Stop!!!
Stuck on logo...
Old 11-05-2016, 05:05   #11 (permalink)
Rex
Member: 3468
Thanks Meter: 299
Update your device with update.zip
Old 11-06-2016, 09:50   #12 (permalink)
Member: 107839
Sonork: 100.1592822
Thanks Meter: 70
tried all firmwares from meizo support up to 5.11
still hang on logo
can u pls upload the firmware mrt suggest from baidu to mega?
b.r
Old 01-31-2017, 00:33   #13 (permalink)
Member: 1965404
doesn't work like u said.
Old 01-31-2017, 18:57   #14 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,867
Read it !!
Old 02-15-2017, 14:13   #15 (permalink)
Member: 2685196
Thanks Meter: 4
any help with same problem ., or correct steps to flash pro 5 ?
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16897 seconds with 7 queries
