GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   MRT - Mobile repair tool (https://forum.gsmhosting.com/vbb/f492/)
-   -   redmi note3 mi account always filed (https://forum.gsmhosting.com/vbb/f492/redmi-note3-mi-account-always-filed-2164863/)
diesel6 12-06-2016 11:49
cant remove mi account from redmi note3 always error
writing date
pls give me slution
.::ARD::. 12-06-2016 12:26
Give screenshot ... And make sure driver has installed
Mishel 12-07-2016 11:18
1 Attachment(s)
same problem, driver installed, Miflash work fine
.::ARD::. 12-07-2016 11:47
Better use depth flash cable or change with other cable
Mishel 12-07-2016 12:10
used deep Flash cable, fastboot reboot to edl and different driver, same result
zbilqis 12-07-2016 17:29
Uninstal all driver and instal again
Think fast no need asking fast bro
Mishel 12-07-2016 22:33
Explained to please the sequence of actions to remove the Mi account. Which phone mode should be in operation? 9008, fastboot. normal?
To zbilqis: very useful answer :D you will soon have 100 posts
A^A 12-08-2016 04:18
Quite simple step actually:
I assume all drivers are installed properly
1. Don't open MRT yet, keep it close
2. Plug the cable into the phone, and put it on EDL mode
3. Make sure it's properly detected in device manager
4. Open MRT, pick Redmi Note 3 from drop down list
5. Finally click Remove Account
Done, turn it on, enable adb, and proceed Remove APK steps.
Hope that helps
Mishel 12-08-2016 08:01
windows 10 64 bit suported?
A^A 12-08-2016 09:10
off course, i'm using it right now
http://image.prntscr.com/image/53a42...0d2e699ea4.png
Mishel 12-08-2016 09:33
Your guide is correct, it worked! To remove the APK need Root?
Mishel 12-08-2016 09:46
1 Attachment(s)
when removing .apk i got an error
A^A 12-08-2016 10:00
No need root at all.
If looking at your screenshot, seems MRT failed to get user permissions from phone.
I already explain this issue in another thread.
Nevermind, I will repeat here:
1. Make sure adb driver that installed in your system is the latest one.
2. Don't open MRT yet
3. Enable ADB in the phone (you know how to do this one)
4. Plug the cable into the phone, make sure phone properly detected in the device manager
5. Open ADB CMD prompt, and type adb devices, look at your phone screen, there should be an ADB notification ask for manual permission
6. Dont forget to TICK (always give) and click OK to allow it
7. Open MRT, finally click Remove APK
It should be okay by now
Mishel 12-08-2016 10:33
Thank you for your patience, I'll try. How many time it takes to delete APK? Firmware Version matter?
A^A 12-08-2016 11:53
Should be quick, a minute or two, better using version 7.3.2 for higher success rate, especially for Note 3 Pro
Page generated in 0.24247 seconds with 5 queries
