01-21-2019, 09:43 | #1 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 580100 Status: Offline Thanks Meter: 16 | OPPO F5 new security dead after frp pinout (need help) i formatted OPPO f5 cph1723 new security with mrt using TP after formatting everything seems ok but it still has FRP so I decided to remove the FRP with TP using MRT but unluckily it wont boot anymore the pc still can detect it as MediaTek usb port does anyone experienced it I would highly appreciate any workaround for this one |
The Following User Says Thank You to liera For This Useful Post: |
01-21-2019, 10:21 | #2 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Pakistan Faisalabad Age: 41
Member: 177381 Status: Offline Sonork: 100.162218 Thanks Meter: 16 | press emergency dialler write *#812# code frp will reset |
The Following 2 Users Say Thank You to nabeel_7152077 For This Useful Post: |
01-21-2019, 11:35 | #8 (permalink) | |
Member: 580100 Status: Offline Thanks Meter: 16 | Quote: yes sir, Its just that I've been out of my mind forgetting to take the screenies after it wont boot anymore I already have oppo phones with new security succesful in removing frp using tP with mrt but maybe I just didnt get lucky in this one. | |
01-21-2019, 11:46 | #9 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 784847 Status: Offline Thanks Meter: 45 | I had also the same problem dead f5 after tp unlock phone was connecting with pc but not power on solution... Simply clean tp soldering area with good liquid there is must some kind of shortage with tp.... Every thing will be fine good luck |
01-21-2019, 12:11 | #10 (permalink) | |
I'll try it sir if it would work | |
01-22-2019, 13:16 | #12 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Vancouver BC & Kathmandu Nepal
Member: 538410 Status: Offline Sonork: 100.1590750 Thanks Meter: 193 | Quote:
and for future reference the best option is only to do format any oppo mtk model with testpoint never do the reset frp after format just power on the phone and connect to the wifi do the rest step there should not be frp even if u get frp locked after that too try the code *#812# | |
The Following 3 Users Say Thank You to robean For This Useful Post: |
01-23-2019, 12:54 | #14 (permalink) | |
thanks sir but I tried the online flashing for oppo but they said that it was due to TP and it was to be repaired thru hardware, I dont even think that it was because of TP since I didnt soldered the resistor to have it touched the ground, I use twizzer to connect it to ground and the resistor isn't damaged at all. | |
01-24-2019, 06:52 | #15 (permalink) |
Member: 538410 Status: Offline Sonork: 100.1590750 Thanks Meter: 193 | Did u flash via online with lastest version and did the online flashing is complete or not |
The Following User Says Thank You to robean For This Useful Post: |
