Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 10-06-2016, 08:24   #61 (permalink)
Member: 1544599
Thanks Meter: 224
Story of Success MRT Product [ Read/Write/Format/Unlock...etc ]
MRT UNLOCK PASSCODE MEIZU MX5
https://www.youtube.com/watch?v=roz8IQ2z9zE
Old 10-06-2016, 10:00   #62 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
Cool Story of Success MRT Product [ Read/Write/Format/Unlock...etc ]
meizu note 3 unlock done in few sec: mrt dongle
WBR
THE MOBILE SHOP
Old 10-07-2016, 14:41   #63 (permalink)
Crazy Poster
Member: 1971921
Thanks Meter: 24
Searching Android Mobile...
Get the Android Deivers
Mobile SN Info: 86132B0423AE
>>>>Trying Connect to Service verification data...
Checking Bootload Infoverify success Success
Now Change Mobile SN Info...
SN Info has Move to 86152B0423AE Success...
>>>>Flashing Facotry Frimware...
Writeing Block proinfo...Success
Writeing Block bootimg...Success
Writeing Block recovery...Success
Writeing Block ldfw...Success
Writeing Block bootloader...Success
Writeing Block system...Success
Writeing Block userdata...Success
Writeing Block custom...Success
Writeing Block dtb...Success
Writeing Block bootlogo...Success
Try Get Recovery auth...
Setting Recovery Auth Success...
Mobile will reboot;reboot to factory firmware model
Waiting it reboot done,power off
after power off,you need let the mobile into Recovery
and update your device with update.zip
Corresponding operation completed!!!
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
Old 10-08-2016, 09:24   #64 (permalink)
Rex
Member: 3468
Thanks Meter: 308
Vivo X7 Account Password Remove Done
The Following 4 Users Say Thank You to Rex For This Useful Post:
Old 10-10-2016, 07:21   #65 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
REDMI NOTE 3 PRO - MICLOUD UNLOCKED DONE BY MRT DONGLE
BECAUSE NO ONE HAVE,... BUT WE HAVE!!!
The Following 2 Users Say Thank You to .::ARD::. For This Useful Post:
Old 10-10-2016, 09:39   #66 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
MI 4S - MICLOUD REMOVED DONE BY MRT DONGLE
Qualcomm HS-USB QDLoader 9008 (COM10)
>>>>Init Device and Connect it...Success
>>>>Set Boot Filerog_emmc_firehose_8992_ddr.mbn
>>>>Set Flash File:rawprogram0.xml
>>>>Reading Mobile Info...
Version 2.15
SerialNumber: 0x020ee725
MSM_HW_ID: 0x009690e1
OEM_PK_HASH: 0x57158eaf1814d78fd2b3105ece4db18a817a08ac664a5782 a925f3ff8403d39a
SBL SW Version: 0x00000000
Status: 0 The operation completed successfully.
>>>>Writing Unlock Date...
The Following User Says Thank You to .::ARD::. For This Useful Post:
Old 10-12-2016, 10:42   #67 (permalink)
ajay19557's Avatar
Member: 2472069
Thanks Meter: 82
good work
redmi 3s pattern removed one clicl in recovery mode
by mrt
thnx for good work
Old 10-12-2016, 10:43   #68 (permalink)
ajay19557's Avatar
Member: 2472069
Thanks Meter: 82
mmx q371 dead alive success with mrt
other still failed
Old 10-12-2016, 10:46   #69 (permalink)
ajay19557's Avatar
Member: 2472069
Thanks Meter: 82
one more redmi 3s lock removed one click by mrt
no one have what mrt have
Old 10-13-2016, 06:22   #70 (permalink)
ajay19557's Avatar
Member: 2472069
Thanks Meter: 82
Redmi 3s prime mi account removed done one click
(need flash after unlock)
MRT
(no one have what mrt have)
Old 10-13-2016, 06:24   #71 (permalink)
ajay19557's Avatar
Member: 2472069
Thanks Meter: 82
xiaomi MI5 user lock removed one click in recovery
MRT
Old 10-13-2016, 15:55   #72 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 245
successfully remove xiaomi MI5 by one click
device must be mode EDL
Use deep Flash Cable to mode EDL
print screen windows xp
Old 10-14-2016, 12:32   #73 (permalink)
Member: 1616754
Thanks Meter: 245
Success remove micloud redmi 3A
after success in the cloud mi account remove the device can already master reset
not lock again after connect wifi
>>>>Get the Qualcomm 9008 Driver...
Qualcomm HS-USB QDLoader 9008 (COM14)
>>>>Set Boot Filerog_emmc_firehose_8937_ddr.mbn
Version 2.15
SerialNumber: 0x0078094e
MSM_HW_ID: 0x0004f0e1
tip:
after unlock,If Connect network,maybe it will lock again
Then you need unlock again,and Remove the cloud apk
After Remove Cloud,Some Xiaomi APK will not wroking
This is a beta function;not sure can working will all
Some Set Mobile Phone need flash MIUI7.5 or > 7.5 first
Connect to Service Success!!!
Old 10-14-2016, 12:32   #74 (permalink)
Member: 1616754
Thanks Meter: 245
Version 2.15
tip:
Old 10-16-2016, 09:30   #75 (permalink)
Member: 1038939
Thanks Meter: 99
M2 Meizu flashing factory FW
    Disconnect Mobile...
    Re-Put the Mobile Bettery...
    Then Connect your Phone to Computer again....
    Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
    Get Mobile Port is:  COM4
>>> Device driver identification:
    MediaTek USB Port
>>> Mobile Has Connect...
    CPU_NAME: MT6735
>>> Reading Mobile Hardware Info...Success
    HW_Inf:  8A00    SW_Inf:  CA00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
Success
>>> Downloading Boot1 To Mobile Phone...Success
    The Flash Hardware Info:R821MB
>>> Downloading Boot2 To Mobile Phone...
>>> Initializationing Mobile Hardware Parameter...Success
    =====================Flash Type(eMMC)==============
    Flash   Size: 0x00000003A3E00000 -> 14910M
    Flash     ID: 0x150100523832314D
    Flash   Name: Samsung_KMR820001M_B609
    Flash symbol: R821MB
>>> Software Auto Switch Hight Speed Has Enable...
>>> Swich Mobile to Hight Speed Re\Wr Port...
    Get Mobile Port is:  COM5
    MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Success
    Writeing Mobile Initialization 1...Success
    ХэФЪРґИлїйРЈСй   lk.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   boot.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   recovery.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   logo.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   secro.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   tee1.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   tee2.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   custom.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   system.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   cache.... іЙ№¦!!!
    ХэФЪРґИлїйРЈСй   userdata.... іЙ№¦!!!
    Writeing Block  6  lk....Success
    Writeing Block  8  boot....Success
    Writeing Block  9  recovery....Success
    Writeing Block  10  logo....Success
    Writeing Block  14  secro....Success
    Writeing Block  16  tee1....Success
    Writeing Block  17  tee2....Success
    Writeing Block  18  custom....Success
    Writeing Block  22  system....Success
    Writeing Block  23  cache....Success
    Writeing Block  24  userdata....Success
Screen - https://yadi.sk/i/apo6AuVewvaUm
Erase userdata after flashing.
The Following User Says Thank You to Mumang For This Useful Post:
Page generated in 0.34680 seconds with 10 queries
