05-09-2017, 09:47 | #271 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM8 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6795 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:016G72 >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x1101003031364737 Flash Name: Toshiba_Unknow Flash symbol: 016G72 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM9 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM9 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x00B3000000 Size(HEX):0x02F4880000 Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
05-13-2017, 12:22 | #274 (permalink) |
Freak Poster Join Date: May 2009
Member: 1038939 Status: Offline Thanks Meter: 99 | Lenovo A890E Read Flash Done by custom loader. http://prnt.sc/f7bu7a >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x00765C41 MSM_ID: 0x008150E1 CPU name: MSM8612 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>Reading Mobile pmt data...Success Backuping Block:modem... Add(hex):0x04000000 Size(hex):0x04000000 >>>>Saveing mobile block data ...Success Backuping Block:sbl1... Add(hex):0x08000000 Size(hex):0x00080000 >>>>Saveing mobile block data ...Success Backuping Block:sdi... Add(hex):0x08080000 Size(hex):0x00020000 >>>>Saveing mobile block data ...Success Backuping Block:rpm... Add(hex):0x080A0000 Size(hex):0x0007D000 >>>>Saveing mobile block data ...Success Backuping Block:aboot... Add(hex):0x0811D000 Size(hex):0x00200000 >>>>Saveing mobile block data ...Success Backuping Block:fsc... Add(hex):0x0831D000 Size(hex):0x00000400 >>>>Saveing mobile block data ...Success Backuping Block:ssd... Add(hex):0x0831D400 Size(hex):0x00002000 >>>>Saveing mobile block data ...Success Backuping BlockDR... Add(hex):0x0C000000 Size(hex):0x00008000 >>>>Saveing mobile block data ...Success Backuping Block:boot... Add(hex):0x0C008000 Size(hex):0x01400000 >>>>Saveing mobile block data ...Success Backuping Block:recovery... Add(hex):0x0D408000 Size(hex):0x01400000 >>>>Saveing mobile block data ...Success Backuping Block:splash... Add(hex):0x0E808000 Size(hex):0x01400000 >>>>Saveing mobile block data ...Success Backuping Block:mrd... Add(hex):0x10000000 Size(hex):0x08000000 >>>>Saveing mobile block data ...Success Backuping Block:tz... Add(hex):0x18000000 Size(hex):0x0007D000 >>>>Saveing mobile block data ...Success Backuping Blockad... Add(hex):0x1807D000 Size(hex):0x00100000 >>>>Saveing mobile block data ...Success Backuping Block:modemst1... Add(hex):0x1817D000 Size(hex):0x00180000 >>>>Saveing mobile block data ...Success Backuping Block:modemst2... Add(hex):0x182FD000 Size(hex):0x00180000 >>>>Saveing mobile block data ...Success Backuping Block:fsg... Add(hex):0x1847D000 Size(hex):0x00180000 >>>>Saveing mobile block data ...Success Backuping Blockersist... Add(hex):0x185FD000 Size(hex):0x02000000 >>>>Saveing mobile block data ...Success Backuping Block:misc... Add(hex):0x1A5FD000 Size(hex):0x00100000 >>>>Saveing mobile block data ...Success Backuping Block:cache... Add(hex):0x1C000000 Size(hex):0x08000000 >>>>Saveing mobile block data ...Success Backuping Block:system... Add(hex):0x24000000 Size(hex):0x40000000 >>>>Saveing mobile block data ...Success You Has Select ReadBack Flash With userdata... and software has read it a little only Backuping Block:userdata... Add(hex):0x64000000 Size(hex):0x01000000 >>>>Saveing mobile block data ...Success Corresponding operation completed!!! |
05-14-2017, 09:24 | #275 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO X9 account done. >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>ีิฺวะปปตฝถมะดฤฃสฝSuccess Flasy type: eMMC Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal Last edited by wsmobile; 05-14-2017 at 09:29. |
05-14-2017, 10:01 | #276 (permalink) |
Freak Poster Join Date: Jun 2013 Location: india tirupur tamilnadu
Member: 1962832 Status: Offline Thanks Meter: 199 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] __________________ Best Regards a1mobiletirupur * Always Follow Forum Rules Here * Use Only Thanks Button * Use Search Button Before make a Thread |
The Following User Says Thank You to a1mobiletirupur For This Useful Post: |
05-14-2017, 18:21 | #277 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: USA
Member: 1361178 Status: Offline Thanks Meter: 95 | Quote:
Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM60 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000002A3E00000 -> 10814M Flash ID: 0x150100513832334D Flash Name: Samsung_Unknow Flash symbol: Q823MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM61 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x02B7DFBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! Thanks!! | |
05-16-2017, 20:22 | #278 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | World first - Bq x5 plus format ok Quote:
05-17-2017, 13:36 | #281 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | oppo f1s (a1601) only vibrate back in life with great mrt Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM11 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000D8F800000 -> 55544M Flash ID: 0x150100524331344D Flash Name: Samsung_Unknow Flash symbol: RC14MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM12 >>> Device driver identification: DA USB VCOM Port >>>>Flashing preloader Block data to Moblile Phone... Start: 0x0000000000 Size: 0x000002C284 >>>>Flashing recovery Block data to Moblile Phone... Start: 0x0000008000 Size: 0x0000E27800 >>>>Flashing md1img Block data to Moblile Phone... Start: 0x000AB00000 Size: 0x0001136660 >>>>Flashing md1dsp Block data to Moblile Phone... Start: 0x000C300000 Size: 0x00000E9FB0 >>>>Flashing md1arm7 Block data to Moblile Phone... Start: 0x000C700000 Size: 0x00000302B0 >>>>Flashing md3img Block data to Moblile Phone... Start: 0x000CA00000 Size: 0x0000000001 >>>>Flashing lk Block data to Moblile Phone... Start: 0x000D400000 Size: 0x000004EED0 >>>>Flashing lk2 Block data to Moblile Phone... Start: 0x000D500000 Size: 0x000004EED0 >>>>Flashing boot Block data to Moblile Phone... Start: 0x000D600000 Size: 0x0000921800 >>>>Flashing logo Block data to Moblile Phone... Start: 0x000E600000 Size: 0x0000335A20 >>>>Flashing tee1 Block data to Moblile Phone... Start: 0x000EE00000 Size: 0x000006C4A0 >>>>Flashing tee2 Block data to Moblile Phone... Start: 0x000F300000 Size: 0x000006C4A0 >>>>Flashing secro Block data to Moblile Phone... Start: 0x000F800000 Size: 0x0000021000 >>>>Flashing system Block data to Moblile Phone... Start: 0x0010800000 Size: 0x00B5DA44E0 >>>>Flashing cache Block data to Moblile Phone... Start: 0x00D1000000 Size: 0x000061A0D0 >>>>Flashing userdata Block data to Moblile Phone... Start: 0x00E1000000 Size: 0x000634F3B8 Corresponding operation completed!!! |
The Following User Says Thank You to diesel6 For This Useful Post: |
05-20-2017, 17:12 | #282 (permalink) |
Freak Poster Join Date: Feb 2008 Location: India.Tamilnadu Age: 44
Member: 700441 Status: Offline Thanks Meter: 71 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] A1601 Finger print lock relese Done upload picture image hosting services pc screenshot Regards Kanth.suresh |
05-23-2017, 04:46 | #284 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO A57 done. >>>Try connect to mobile...Success CPU_SN: 0x12450D4C MSM_ID: 0x0006B0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>Reading Mobile pmt data...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00E0C82000 Size:0x0666F79E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
05-24-2017, 14:57 | #285 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Russia, Ivanovo city
Member: 2006990 Status: Offline Thanks Meter: 540 | Xaomi Redmi 2 Reset Lock Done Connecting Mobile Phone... please connect your phone as fastboot... Clear Mobile data... Creating filesystem with parameters: Size: 5939113984 Block size: 4096 Blocks per group: 32768 Inodes per group: 8064 Inode size: 256 Journal blocks: 22655 Label: Blocks: 1449979 Block groups: 45 block group size: 359 Created filesystem with 11/362880 inodes and 48316/1449979 blocks Creating filesystem with parameters: Size: 335544320 Block size: 4096 Blocks per group: 32768 Inodes per group: 6832 Inode size: 256 ournal blocks: 1280 Label: Blocks: 81920 Block groups: 3 Reserved block group size: 23 Created filesystem with 11/20496 inodes and 2620/81920 blocks < waiting for device > target reported max download size of 268435456 bytes ng 'userdata'... OKAY [ 0.828s] sending 'userdata' (94509 KB)... OKAY [ 2.953s] writing 'userdata'... OKAY [ 2.359s] erasing 'cache'... OKAY [ 0.062s] sending 'cache' (6972 KB)... OKAY [ 0.219s] writing 'cache'... OKAY [ 0.188s] . total time: 6.609s Clear Mobile account data... erasing 'persist'... OKAY [ 0.031s] finished. total time: 0.031s reboot mobile set... rebooting... finished. total time: 0.000s Connect to Service Success!!! |
The Following User Says Thank You to Surtax For This Useful Post: |
