03-24-2018, 12:46 | #856 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 44
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM196 >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom... 手机状态为: preloader Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100474536424D Flash Name: Samsung_Unknow Flash symbol: GE6BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM26 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x013D000000 Size(HEX):0x0265DFBE00 Corresponding operation completed!!! |
The Following User Says Thank You to diesel6 For This Useful Post: |
03-25-2018, 05:48 | #857 (permalink) |
Freak Poster Join Date: Nov 2017 Location: malaysia
Member: 2782332 Status: Offline Thanks Meter: 185 | frp huawei nova lite success >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: PRA-LX2 Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:85e376738e811f45 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) The device will reboot and do factory reset... OKAY [ 0.016s] finished. total time: 0.016s >>>>Rebooting Mobile Phone |
03-29-2018, 05:40 | #860 (permalink) |
Member: 2782332 Status: Offline Thanks Meter: 185 | frp vivo v5s 1713 success turn off device press button volume + and insert usb cable Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM10 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x1501005248363441 Flash Name: Samsung_Unknow Flash symbol: RH64AB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM27 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
03-30-2018, 09:49 | #861 (permalink) |
Member: 2782332 Status: Offline Thanks Meter: 185 | format oppo a77 (erase pattern lock) Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM10 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM27 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x0137000000 Size(HEX):0x0D577FBE00 Corresponding operation completed!!! |
03-31-2018, 07:31 | #862 (permalink) |
Insane Poster Join Date: May 2010 Location: kepri
Member: 1310144 Status: Offline Thanks Meter: 15 | Huawei WAS-LX2 FRP done >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: WAS-LX2 Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:7e0d77f2ce98aeeb Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) The device will reboot and do factory reset... OKAY [ 0.031s] finished. total time: 0.031s >>>>Rebooting Mobile Phone rebooting... finished. total time: -0.000s |
The Following User Says Thank You to 4S3N For This Useful Post: |
03-31-2018, 07:33 | #863 (permalink) |
Member: 1310144 Status: Offline Thanks Meter: 15 | OPPO A37F pattern lock >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x1BD14721 MSM_ID: 0x007050E1 CPU型号: MSM8916 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>正在读取手机分区数据...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00E2788000 Size:0x02C1673E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
03-31-2018, 12:13 | #864 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO R9 plus a done. >>>Try connect to mobile...Success CPU_SN: 0x0200FDF9 MSM_ID: 0x009900E1 CPUะอบล: MSM8976 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00C4482000 Size:0x0DCB379E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to wsmobile For This Useful Post: |
04-01-2018, 09:01 | #865 (permalink) |
Member: 1310144 Status: Offline Thanks Meter: 15 | OPPO CPH1723 Format Done Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM7 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM5 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
04-01-2018, 09:21 | #866 (permalink) |
Member: 1310144 Status: Offline Thanks Meter: 15 | MT6735 FRP Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM4 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware InfoF4016 >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x4501004446343031 Flash Name: Sandisk_Unknow Flash symbol: DF4016 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM5 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM5 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0006A00000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
04-02-2018, 05:38 | #867 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Meizu m611h done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM160 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100514531334D Flash Name: Samsung_Unknow Flash symbol: QE13MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM266 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x02B7DFBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
04-03-2018, 11:21 | #870 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO F5 done Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
