08-22-2018, 05:24 | #976 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM68 >>> Device driver identification: MediaTek USB Port_V1632 >>> Mobile Has Connect... CPU_NAME: MT6797 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom...Success Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100424A4E4234 Flash Name: Samsung_Unknow Flash symbol: BJNB4R >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM233 >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00EB800000 Size(HEX):0x065B3F8000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
08-27-2018, 08:30 | #977 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Redmi Note 5A Prime done. >>>Try connect to mobile...Success CPU_SN: 0x3FB70797 MSM_ID: 0x0006B0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC CPU Type: 8937" / >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Write Add :7995392Success Write Add :7995400Success Write Add :7995408Success Write Add :7995464Success Write Add :7995480Success Write Add :7996504Success Write Add :8004704Success Write Add :8004712Success Write Add :8004728Success Write Add :8004744Success Write Add :8004816Success Write Add :8004848Success Write Add :8004864Success Corresponding operation completed!!! |
08-30-2018, 16:14 | #978 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1723 PinLock Format Code: Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM65 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Geting Mobile info data... ADD(HEX):0x0021800000 Size(HEX):0x0158000000 识别到ext4文件系统.... ro.build.id=N6F26Q ro.build.display.id=CPH1723EX_11_A.28_180807 ro.build.version.release=7.1.1 ro.product.model=OPPO CPH1723 ro.product.brand=OPPO ro.product.name=CPH1723 ro.product.device=M6763A ro.product.board=full_oppo6763_17031 ro.product.manufacturer=OPPO ro.board.platform=mt6763 ro.mediatek.platform=MT6763 ro.mediatek.chip_ver=S01 Corresponding operation completed!!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM65 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
09-04-2018, 17:38 | #981 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | Huawei Mate 10 lite RNE-L21 frp remove done with MRT Code: >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: RNE-L21 Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:042fe8ba1f2d3b50>>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:6bfdbcc8312dfb03 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) The device will reboot and do factory reset... OKAY [ 0.015s] finished. total time: 0.015s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.000s |
The Following User Says Thank You to Bmszone For This Useful Post: |
09-06-2018, 07:56 | #982 (permalink) |
No Life Poster Join Date: Feb 2014 Location: gsm
Member: 2131081 Status: Offline Sonork: 76543322223 Thanks Meter: 92 | mi 5s frp done >>>Try connect to mobile...Success CPU_SN: 0x588791B0 MSM_ID: 0x0005F0E1 >>>Try connect to mobile...Success >>> Initialization Mobile ...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: UFS CPU Type: MSM8996 Corresponding operation completed!!! |
09-10-2018, 12:18 | #983 (permalink) | |
Member: 2131081 Status: Offline Sonork: 76543322223 Thanks Meter: 92 | nokia 6 frp remove done Quote:
09-13-2018, 15:16 | #986 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 356508 Status: Offline Thanks Meter: 132 | Xiaomi Mi A1 8.0 FRP done >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0xA4AAC3EC MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>read mobile GPT data...Success Eraseing Block frp ADD:0x01AA180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal THX BR |
09-14-2018, 16:11 | #987 (permalink) | |
Member: 2131081 Status: Offline Sonork: 76543322223 Thanks Meter: 92 | redmi note 4x mi account removed Quote:
09-16-2018, 16:07 | #988 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Redmi S2 YSL Unlock Micloud Done mrt ver 2.59 |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
09-17-2018, 07:35 | #989 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | Redmi s2 mi account removed succesfully >>>Try connect to mobile...Success CPU_SN: 0xFA0886B6 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC CPU Type: 8953" / >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0x0008000000 Size: 0x0x0004000000 Write Add :262144Success Write Add :262152Success Write Add :262160Success Write Add :262216Success Write Add :262232Success Write Add :263256Success Write Add :271448Success Write Add :271456Success Write Add :271464Success Write Add :271472Success Write Add :271536Success Write Add :271560Success Write Add :271568Success Write Add :271576Success Write Add :271584Success Write Add :271592Success Write Add :271600Success Write Add :271608Success Write Add :271616Success >>>>Writing Unlock Date... Start: 0x0x000C000000 Size: 0x0x0004000000 Write Add :393216Success Write Add :393224Success Write Add :393232Success Write Add :393288Success Write Add :393304Success Write Add :394328Success Write Add :402520Success Write Add :402528Success Write Add :402536Success Write Add :402544Success Write Add :402608Success Write Add :402632Success Write Add :402640Success Write Add :402648Success Write Add :402656Success Write Add :402664Success Write Add :402672Success Write Add :402680Success Write Add :402688Success Eraseing Block frp ADD:0x0000028000 Size:0x0000010000 Success Corresponding operation completed!!! |
The Following 2 Users Say Thank You to mmurugan1978 For This Useful Post: |
