Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 03-21-2019, 12:23   #1156 (permalink)
Member: 2750401
Thanks Meter: 134
Redmi note 3 MTK account done
>>> Searching Mobile Port...
Get Mobile Port is: COM15
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6795
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CA00
>>> Initialization Mobile ...>>> Downloading Boot1 To Mobile Phone...Success
The Flash Hardware Info:032G74
>>> Downloading Boot2 To Mobile Phone...
>>> Initializationing Mobile Hardware Parameter...Success
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000747C00000 -> 29820M
Flash ID: 0x1101003033324737
Flash Name: Toshiba_Unknow
Flash symbol: 032G74
>>> Software Auto Switch Hight Speed Has Enable...
>>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM16
MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Success
>>> Extracting valid data from partition data...
>>>>Formating Mobile USER Data...
ADD(HEX):0x00B3000000 Size(HEX):0x0691080000
ADD(HEX):0x0001280000 Size(HEX):0x0000A00000
Corresponding operation completed!!!
The Following 2 Users Say Thank You to dimasc For This Useful Post:
Old 03-23-2019, 17:56   #1157 (permalink)
allen128's Avatar
Member: 277327
Thanks Meter: 34
OPPO F9 format and bypass FRP done.
Sent from my iPhone using Tapatalk
The Following 2 Users Say Thank You to allen128 For This Useful Post:
Old 03-24-2019, 15:29   #1158 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,144
Talking Huawei Honor 7c FRP Reset Done
Mobile Name: LND-L29
Mobile Set BL Lock state:ser Lock state is lock
Trying First Way for Get the Unlock code
Dynamic unlock code
>>>>try temp unlock bootloader function 2...
Dynamic unlock code:
Try Qualcomm temp Bootloader unlock new function...
Bootloader Temporary Unlock Done
tip:Bootloader Temporary after reboot will lock again
>>>>Clear Frp Block
(bootloader) Erase success , the device will reboot and factory reset
OKAY [ 0.028s]
finished. total time: 0.028s
>>>>Rebooting Mobile Phone
rebooting...
finished. total time: -0.000s
The Following 2 Users Say Thank You to rafi_5217705 For This Useful Post:
Old 03-26-2019, 11:25   #1159 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 785
Redmi 3 Mi Account Remove Done Without Open Set and Without EDL CABLE
Hi Every one ,
Today i will Teach you that how to Remove Redmi Account From Mi Redmi3 with easy Procedure without open phone and also use EDL Cable Just Follow Procedure You Need MRT DONGEL
Procedure :
1) Turn OFF Device
2) Press and Hold Volum UP and Connect Phone With Computer with Cable
3) You Will See Recovery Menu
4) All Menu will be in Chines You will Chose English
5) Click Right Side down From recovery Now All Menu will be in English
6) Now Press Recovery Option in Menu
7) Check Drivers Need to install
8) Now Phone in Recovery Mode and you will see Mobile Picture on Screen
9) Open MRT SETUP & CLick on Xiomi
10) Chose Model in Device 11) Now Just Click on ( Unlock Password With BL Lock Phones See Your Phone is Done Now you Can Restart Your Phone
Now Watch Video
http://www.youtube.com/watch?v=z6tK7nIBkeg
WBGSM
The Following 3 Users Say Thank You to WBGSM For This Useful Post:
Old 03-28-2019, 18:49   #1160 (permalink)
Member: 2750401
Thanks Meter: 134
Meizu M6 Note password done
>>>>Auto search Mobile port...
>>>Try connect to mobile...Success
CPU_SN: 0x4CC8DE8A
MSM_ID: 0x000460E1
>>>init mobile...Success
>>>Downloading boot...Success
>>>Switch mobile to RE\WR ...Success
Flasy type: eMMC
>>>>read mobile GPT data...Success
Clear Moblile Lock data...
After Click Mobile userdata will be lost...
Format add: ADD:0x0174000000 Size:0x05D3BFBE00
Erase Userdata.. Success
Erase Userdata Block 2...
Erase Userdata Block 3...
Erase Userdata Block 4...
>>>>rebooting mobile phones
reboot mobile success
>>>all is done
Please disconnect mobile set,and hold vol up and power key
Mobile will be into recovery
Click Restart
if mobile hand on logo or auto restart...
You can in recovery erase data
After ease data in recovery mobile will working normal
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
Old 03-30-2019, 11:06   #1161 (permalink)
Member: 2256970
Thanks Meter: 67
nokia 3 frp done
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
Get Mobile Port is: COM3
MediaTek PreLoader USB VCOM (Android)
CPU_NAME: MT6735
HW_Inf: 8A00 SW_Inf: CB00
>>> Initialization Mobile ...Success
The Flash Hardware Info:JHAG4a
>>> Downloading Boot2 To Mobile Phone...Success
Flash Size: 0x00000003AB400000 -> 15028M
Flash ID: 0x90014A4841473461
Flash Name: Hynix_Unknow
Flash symbol: JHAG4a
ADD(HEX):0x0009B20000 Size(HEX):0x0000100000
The Following 2 Users Say Thank You to Naps For This Useful Post:
Old 04-03-2019, 17:01   #1162 (permalink)
Member: 2233266
Thanks Meter: 252
COOLPAD MEGA 2.5D(Y83-I00) FRP DONE MRT DONLGE
Get Mobile Port is: COM4
CPU_NAME: MT6735
Get Mobile Port is: COM10
ADD(HEX):0x000C680000 Size(HEX):0x0000100000
The Following 2 Users Say Thank You to Yahia_Sb For This Useful Post:
Old 04-05-2019, 19:32   #1163 (permalink)
Member: 503942
Thanks Meter: 61
Nokia 3 Android 8.1.0 (security II 2019) FRP OK.
Get Mobile Port is: COM11
CPU_NAME: MT6735
The Flash Hardware Info:NQ2J96
Flash ID: 0x13014E51324A3936
Flash Name: UNKNOWN
Flash symbol: NQ2J96
Get Mobile Port is: COM13
The Following 2 Users Say Thank You to suchywilk For This Useful Post:
Old 04-06-2019, 08:33   #1164 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Oppo a83 cph 1729 latest security a21 version pin lock remove by test point by mrt
OPPO A83 CPH 1729 LATEST SECURITY A21 VERSION PIN LOCK REMOVE BY TEST POINT BY MRT
Old 04-06-2019, 08:34   #1165 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Comio c1 frp remove in 1 click by mrt
COMIO C1 FRP REMOVE IN 1 CLICK BY MRT
Old 04-06-2019, 08:35   #1166 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Comio c2 frp remove 1 click by mrt
COMIO C2 FRP REMOVE 1 CLICK BY MRT
Old 04-06-2019, 08:38   #1167 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Huawei honor tit-al00 frp remove 1 click by mrt
HUAWEI HONOR TIT-AL00 FRP REMOVE 1 CLICK BY MRT
Old 04-06-2019, 08:40   #1168 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Huawei bnd-al10 frp remove 1 click by mrt
HUAWEI BND-AL10 FRP REMOVE 1 CLICK BY MRT
Old 04-06-2019, 08:41   #1169 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Huawei honor lnd-al30 frp remove 1 click by mrt
HUAWEI HONOR LND-AL30 FRP REMOVE 1 CLICK BY MRT
Old 04-06-2019, 08:43   #1170 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Intex aqua lions n1 frp remove 1 click by mrt
INTEX AQUA LIONS N1 FRP REMOVE
1 CLICK BY MRT
Page generated in 0.29393 seconds with 10 queries
