01-17-2018, 07:03 | #766 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | >>>Try connect to mobile...Success CPU_SN: 0x10FB3669 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
01-17-2018, 10:06 | #768 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | MP Agua Rio Lite invalid imei dOne Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM37COM37 >>> Device driver identification: MediaTek DA USB VCOM Port Set Port To COM37Success Into Meta Mode...Success Switch Moile to Repair IMEI Port... >>> Searching Mobile Port... Get Mobile Port is: COM513COM513 >>> Device driver identification: MediaTek USB VCOM (Android) >>> Into META Repair IMEI Mode...Success reading the relevant parameters of the phone information... CPU_TYPE:MT6582,S01 Bulid_Time:Tue Mar 31 17:42:03 CST 2015 Base_Ver:ALPS.L0.MP2.V1_TINNO6582.WT.L_P7 Soft_Ver:ALPS.L0.MP2.V1.WT.L_P18 Original_IMEI 1: New_IMEI 1: 35233006680**** Original_IMEI 2: New_IMEI 1: 35233006695**** Corresponding operation completed!!! |
01-18-2018, 12:36 | #769 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO X20A done. >>>Try connect to mobile...Success CPU_SN: 0x5C25D788 MSM_ID: 0x0008C0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>ีิฺวะปปตฝถมะดฤฃสฝSuccess Flasy type: UFS CPU ภเะอ: MSM8996 >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success ีิฺวๅณสึป๚ห๘สพ... วๅณอ๊ณษบ๓ปแตผึยสึป๚ตฤำรปงสพถชสง... ธ๑สฝปฏตุึท:ADD:0x0181400000 Size:0x0D0E3FBE00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
01-21-2018, 13:37 | #771 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO A77 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM482 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM269 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x0137000000 Size(HEX):0x0D577FBE00 Corresponding operation completed!!! |
01-24-2018, 12:01 | #773 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | TA-1032 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM72 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:NQ2J96 >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x13014E51324A3936 Flash Name: UNKNOWN Flash symbol: NQ2J96 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM269 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM269 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0127000000 Size(HEX):0x0283380000 Corresponding operation completed!!! |
01-25-2018, 08:59 | #776 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO F5 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM34 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525836344D Flash Name: Samsung_Unknow Flash symbol: RX64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM43 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
01-26-2018, 06:09 | #778 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO V5S v7.0 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM54 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM87 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
01-28-2018, 10:11 | #780 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Nokia 3 Frp Removed 1000% Done by MRT Dongle Credited to : arifin |
