TestPoint_OPPPO F7 NEW Security_VEr26 MRT team 1 Attachment(s) |
its good thanks but while format read mobile map data FAIL |
If you failed mean your wrong in handling |
Hi i have different board https://uploads.tapatalk-cdn.com/201...032317b202.jpg Need testpoint for unlock Phone name cph1819 Sent from my iPhone using Tapatalk |
oppo f7 new board new testpoint oppo f7 new board new testpoint A.26 version tested 101% https://i.postimg.cc/c12TC6Zn/oppo-f7-new-testpoint.jpg |
connect to ground while running software? |
question in procedure in testpoint must be connected the battery before insert the usb data cable? in vivo the battery must not connected before insert the usb data cable. oppo also same procedure? |
Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM17 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000D0A303030 -> 53411M Flash ID: 0x2031303035203030 Flash Name: UNKNOWN Flash symbol: 05 000 >>> Reading Mobile Map Data...Fail |
Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM17 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000D0A303030 -> 53411M Flash ID: 0x2031303035203030 Flash Name: UNKNOWN Flash symbol: 05 000 >>> Reading Mobile Map Data...Fail Same problem |
hi ia have same prob any bady have a good solution plz share it thanks Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM43 >>> Device driver identification: MediaTek USB Port_V1632 >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000D0A303030 -> 53411M Flash ID: 0x2031303035203030 Flash Name: UNKNOWN Flash symbol: 05 000 >>> Reading Mobile Map Data...Fail |
When connected with pc , you need fast to disconnect the test point |
it's seems your hold gnd to test point or some time your pc not able to change vcome port change pc |
Try Boot 1 Thats Will be Mak Nyoooz.... |
ive done the testpoint in resistor.. failed at the end of mrt now phone doesnt turn on... tsk.... but still detecting |
