Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 01-11-2019, 21:57   #166 (permalink)
calvinpower's Avatar
Member: 14229
Thanks Meter: 135
Originally Posted by khan 25 View Post
Mobile Has Connect...
CPU_NAME: MT6763
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CA01
>>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000000000000 -> 0M
Flash ID: 0x0000000000000000
Flash Name: UNKNOWN_UNKNOWN
oppo f5 dead help shot test point
HELP...................
HI
It seems that the ground is still connected to your testpoint, The main reason for disconnecting the ground from testpoint is to allow flash chip to be recognized.
The other day I was messing around with my F5 and dropped the resistor. I was getting the same errors as your. my phone is now alive after resolder back the resistor.
The Following User Says Thank You to calvinpower For This Useful Post:
Old 01-13-2019, 18:38   #167 (permalink)
Member: 1578597
Thanks Meter: 35
sorry Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM45
>>> Device driver identification:
MediaTek USB Port
CPU_NAME: MT6763
Flash symbol: >>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM46
MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Fail
Old 01-13-2019, 18:38   #168 (permalink)
Member: 1578597
Thanks Meter: 35
oppo f5 and a83 is not working
MediaTek USB Port
CPU_NAME: MT6763
Old 01-13-2019, 19:48   #169 (permalink)
Member: 14229
Thanks Meter: 135
MediaTek USB Port
CPU_NAME: MT6763
If you start seeing this...
It could only mean one thing. Testpoint was not disconnected at this stage ( Init Mobile BOOT2 ...)
Not to worry, try without connecting the battery.
Make sure you disconnect testpoint at this stage:
"Make sure Mobile status has in :brom..."
Old 01-14-2019, 13:16   #170 (permalink)
Member: 230504
Thanks Meter: 68
oppo f9 new security frp done
best team for oppo and meizu
Old 01-15-2019, 19:18   #171 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 157
I gate same error tray may time tray in 2 pc same error
Old 01-16-2019, 07:14   #172 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
try emmc_1
or don't hold test point while full operation
The Following 2 Users Say Thank You to DYNET For This Useful Post:
Old 01-17-2019, 13:07   #173 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 157
oppo CPH-1723 Unlocke error by mrt
http://www.youtube.com/watch?v=XJi2BKIO3l4
I make jumper for tp & gnd with jumper wire when connect phone brake jumper
wher is i wrong giad me MRT Support
Old 01-17-2019, 13:42   #174 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 157
TP & Mobile about image
Look this my jumpr good or not also hear is my mobile phone about image
Giad me support Sir
Old 01-17-2019, 21:41   #175 (permalink)
Member: 2889019
oppo A3S any solution with mrt?
Old 02-08-2019, 15:32   #176 (permalink)
Member: 2445304
Sonork: 100.1673122
Thanks Meter: 5
Oppo A83 2018 reset FRP done in 5 minutes
Old 02-11-2019, 10:08   #177 (permalink)
Member: 2324128
Originally Posted by rj.any1 View Post
network unlock or hard reset ????????
oppo f5 reading map data...fail
Old 02-13-2019, 14:31   #178 (permalink)
Member: 1421702
oppo F5 ver CPH1723EX_11_A.31_181128 not ok
Old 02-16-2019, 07:16   #179 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
@all we never said solder on test point need quick ground for couple of second for mtk port appear don't solder on component
Old 02-19-2019, 03:11   #180 (permalink)
ali_ipi's Avatar
Member: 1655288
Thanks Meter: 90
Originally Posted by DYNET View Post
OPPO F5 A30 TP METHOD UNLOCK MRT TEAM ) F5 F5 YUTH A83)
HOW TO DO ?
DISASSEMBLE PHONE OPEN SCREW WARRNTY MAY BE VOID OPEN STICKER FOIL PROTECTED ON CPU AND RAM FIND RESISTOR ACCORDING PHOTO SHORT IT WITH GND CONNECT CABLE AND WAIT MTK PORT APPEAR START OPERATION BATTERY CONNECTED NEED
NOTE THIS IS NOT UPDATE THIS JUST SHARED TRICKS IN THIS NOTHING WORLD 1ST AND LAST
A83 TEST POINT
DO NOT SOLDER TEST POINT TO GND LONG TIME IT'S WILL KILL YOUR PHONE
http://www.youtube.com/watch?v=eu6T2vx1qno&t=41s
can we repair imei with this method plz asap
Page generated in 0.30400 seconds with 9 queries
