xiomi note qaulcomm phone can not flash with flashing tool Hi team why i can not flash i can select file when i press start nothing happening? phone is fastboot mode already https://uploads.tapatalk-cdn.com/201...63ec380d7c.jpg |
The phone is bootloader locked! You can't flash in fastboot mode, you must be in edl mode to flash 1.Turn your phone off 2.Hold volume+ and volume- together and insert cable then the phone will be in edl mode then you can flash with mi flash tool. |
If U Want To Fastboot flash Then Need to Unlock Bootloader Put Phone On EDL Model Then Flash Easly |
I spend the same with this module mount the file but it does not start flas and tried with several models but even so I see they do not correct that problem |
from MRT support put phone in hs usb mode (EDL mode) then open software click on refresh then select file and strat i fix my phone use xiao mi flasher |
