Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 08-02-2017, 07:52   #1 (permalink)
Member: 792851
Thanks Meter: 100
xiomi note qaulcomm phone can not flash with flashing tool
Hi team why i can not flash i can select file when i press start nothing happening?
phone is fastboot mode already
Old 08-02-2017, 09:23   #2 (permalink)
Feiselski's Avatar
Member: 2583091
Thanks Meter: 390
The phone is bootloader locked!
You can't flash in fastboot mode, you must be in edl mode to flash
1.Turn your phone off
2.Hold volume+ and volume- together and insert cable then the phone will be in edl mode then you can flash with mi flash tool.
Old 08-02-2017, 10:00   #3 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 3,772
If U Want To Fastboot flash Then Need to Unlock Bootloader
Put Phone On EDL Model Then Flash Easly
Old 08-02-2017, 23:53   #4 (permalink)
Member: 792851
Thanks Meter: 100
thanks for reply but some how i can not put phone in EDL mode i try what u say but soon as i plug the cable in to the phone phone turn on i open phone disconnect battery and try as well doing same thing.is there any other way i can do?
Old 08-04-2017, 13:52   #5 (permalink)
Member: 1639972
Sonork: 1669340
I spend the same with this module mount the file but it does not start flas and tried with several models but even so I see they do not correct that problem
Old 08-05-2017, 01:24   #6 (permalink)
Member: 792851
Thanks Meter: 100
hi use XiaoMiFlash.exe and use this file Note3 qualcomm V8.0.1 unlock file_2
from MRT support put phone in hs usb mode (EDL mode)
then open software click on refresh then select file and strat
i fix my phone use xiao mi flasher
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.11874 seconds with 7 queries
