12-24-2015, 10:42 | #1 (permalink) |
Junior Member Join Date: Dec 2013 Location: Pakistan
Member: 2077582 Status: Offline Thanks Meter: 16 | How To Hard UnBricked LG G3 (All Variants) (Fix Qhsusb bulk _ Qualcomm-9008) NO BOOT , NO RECOVERY , NO DOWNLOAD MODE , NO POWER 1 : Shows "LGE AndroidNet USB port" "LGE AndroidNet USB Modem" 2 : Only Shows "Qualcomm HS-USB QDLoader 9008" Now Start Fixing If You Are On Situation "1" You To Need To Change "LGE AndroidNet USB port" To "Qualcomm 9008" 1- open the phone 2- On MotherBoard Remove The Cover Of "eMMC" 3- short cut the pins in the photo you provided "without the battery" After Connect The "USB Data Cable" After This Your Phone Shows "Unknown Device" In Device Manager So Install Qualcomn Driver Which Provided Below. Reassemble Your Phone And Connect With PC With Out Battary Now Fixing "Qualcomm HS-USB QDLoader 9008" Prerequisites: AQcomm Drivers BBoardDiag v2.99a C) Choose correct TOT File For Your model Here Directory Listing of //Xda/LG G3/Stock/ D) Make sure you have Visual C++ Redistributable Installed https://drive.google.com/file/d/0BwW...FweER1MUU/view 1) Install Qualcomn Drivers 2) Extract Rar Of BoardDiag v2.99a And Run It 3) Extract Zip Of ToT file Which You Download For Your Phone Make Sure You Download Correct ToT File For Your Phone 4) Now See These Picture 1:Put ToT 2:Set Directory (where ToT File Will Extract) 3:Click On Extract Button After Extract ToT You Will Get Files Like This Then 1)Chosse "Chipset" For G3 Choose B2 2)Select Correct COM Port Which Shows in Device Manager i.e, (COM12) 3)Select Source Of file Where ToT file Extraced 4)Tick Into "AP Test" And "EMMC TEST" 5)Click On Start After Both Test Passed Choose Restore Option And Restore These Files One by One In this sequence Note: Don't Change the Sequence 1)Boot 2)Aboot 3)BackupGpt 4)Boot 5)dbi 6)laf 7)PrimaryGpt 8)Recovery 9)rpm 10)tz 11)sbl1 Finished After Complete Disconnect Phone And Insert Battary If Your Phone Boot Up You Have Sucess Then Boot Into Download Mode And Flash ToT File With LG Flash Tool. IF Get Sucess Then Click Thanks Button Take Care Of Yours And Your Phone Special Thanks To This Man For Pictures. @WillCracker Form XDA Developers. |
The Following 14 Users Say Thank You to faisal21 For This Useful Post: |
06-21-2016, 10:36 | #2 (permalink) |
Junior Member Join Date: Jan 2010 Location: KOLLAM.KERALA
Member: 1219380 Status: Offline Sonork: 100.1660760 Thanks Meter: 3 | g3 d858hkn tot g3 d858hk tot file not in download list...please give proper link.. |
The Following User Says Thank You to rajeshbabu For This Useful Post: |
06-24-2016, 18:03 | #4 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2298801 Status: Offline Thanks Meter: 2 | Hi, i try with my lg g3 and i have qualcomm 9008 port in device manager but result "device was not found in dload trying flash programmer" Any solution plz Envoyé de mon LG-F400K en utilisant Tapatalk |
The Following 2 Users Say Thank You to polyctro For This Useful Post: |
07-05-2016, 16:02 | #6 (permalink) |
Freak Poster Join Date: Jan 2006 Location: India (Gujarat) Age: 36
Member: 223135 Status: Offline Sonork: 100.1592685 Thanks Meter: 177 | 100% Working dear.......... Thanks A Lot...... Last edited by uttam; 07-05-2016 at 16:10. |
The Following User Says Thank You to uttam For This Useful Post: |
07-05-2016, 18:20 | #7 (permalink) |
Freak Poster Join Date: Oct 2014 Location: puerto rico
Member: 2282504 Status: Offline Thanks Meter: 50 | umbrick lg ls770 Hi. I have a lg ls770 and after him VZ8 downgrade to vz7 not turned on. in device manager registers as RELINK HS-USB QDLoader 9008. alguin can help me to relive it? Thank you |
The Following User Says Thank You to ltindi32 For This Useful Post: |
09-08-2016, 11:23 | #9 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2622161 Status: Offline Thanks Meter: 1 | Difference Can you tell me please, if is any difference between your scheme and scheme which can you usually find on the internet? Unfortunatelly, i cant post an url. Thanks |
The Following User Says Thank You to Gabzda For This Useful Post: |
09-08-2016, 15:49 | #11 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 579 | Quote:
09-08-2016, 19:03 | #12 (permalink) |
Member: 2622326 Status: Offline Thanks Meter: 1 | i have been following this guide, without succes, BoardDiag part seems right the screen turns on (LG Life's Good powered by android screen) Test again AP and EMMC passed after first try connecting to the PC screen goes off (still recognizes QLoad) but i get errors while on the LG Flash Tool the program says the following Download FAIL!! (8sec) "PID: NULL IMEI: NULL [12:55:30] CrossDL [] to [D855]. SWversion[] 00000064 Error: [12:55:30] CrossDL [] to [D855]. SWversion[]" I'm currently on a D855P 16GB Variant the brick happened while browsing images on Google Chrome i was running Android 6.0 with Root via KingoRoot and TWRP 2.7 at first TWRP was accesible but not able to boot any partition (all of them said 0MB) Tried Flashing a .KDZ file, the Flashtool said Device disconnected every two seconds don`t know what to do now. any help is very well received |
The Following User Says Thank You to CirKraT For This Useful Post: |
10-01-2016, 00:19 | #13 (permalink) |
Insane Poster Join Date: May 2015 Location: KPK Pakistan
Member: 2395555 Status: Offline Sonork: 100.1681674 Thanks Meter: 33 | Asslam O Alaikom..... Superb Work.... My LG d855 is Alive... Thanks Alot....100000000000000% Woking Method |
The Following 2 Users Say Thank You to kingaamir1 For This Useful Post: |
10-12-2016, 20:45 | #15 (permalink) |
Insane Poster Join Date: May 2013
Member: 1942305 Status: Offline Thanks Meter: 4 | i need your help. My Device: LG G3 D855 16GB The device does not turn on, the only thing that appears is because when I connect the device to a PC, I see a driver installed: RELINK HS-USB QDLoader 9008 I downloaded the software BoardDiag 2.9 I downloaded the files to the appropriate TOT I extracted the files by instructors on site. I opened the program and I followed the guide and it seems to me an error Download mode is enabled Mode, I quickly disconnects from the computer and reconnect the computer and then the moment I am unable to do a test and the results are: AP CHECK START = PASS EMMC TEST START FAILED TO OPEN PARTITION FROM EMMC TEST ABORTED !! I tried a lot of tutorials but I can not, it always seems the device is in Download Mode What can I do more? Please your help, |
The Following User Says Thank You to kur10 For This Useful Post: |
