..:kg200 dead after rehot power ic::.. kg200 comes in buzzer problem,so i change buzzer and buzzer ic but still same,then i rehot power ic just below battery connecter so set works fine and buzzer also ok,but after 2 days it again comes in buzzer problem,so i again rehot power ic but now after rehot set becomes dead,i change power ic but still no power.....................so plz kindly help me to solve this problem? its very very urgent? thnx in advance! |
try to use another power ic may b ic u used is damaged.................if still not work thn chk shorting.......test via soft wte phn is booting or not.. |
still no good reply? where is the moderator of this section? |
kg 200 shortttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttttttttttttttttttttttttttt plz help meeeeeeeee urjant |
when i put bettry ...bettry is toooo hot & mobile board plz help meeeeee |
buy new phone ur problem solved becose that is good idea thanks |
man if u have no solution then dont waste forum space with ur stupid posts |
@ HUM Why u are so aggressive? U swap buzzer more then 1 time without success... Maybe there are more parts damage... now or before... Maybe u show us Picture of your work. Maybe u have overheat something... We can't know your soldering skills. :) What u used? Hot Air? Best Regards |
Open your eye's Quote:
Man what u know about there skills HUM is well hardworker and if u don't know about them soo keep learn from other's and look what's going around....????? Remember it..:mad: BR Omairbutt786 |
lg Brother check the power ic i think the problem is power ic try a nother ic but good ic |
thnx but i already solved this problem so thread is closed! |
i havre nokia 6030 dead plz send me proper sloution [email protected] plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz zzzzz |
