LG G3 D855 SIM Connector problem Hi i Have LG G3 D855 Sim Connector one Lage ways how i can fix that http://i60.tinypic.com/wvq0dv.jpg |
any answer ........... ? |
Dig it little bit you will find trace there. Use small wire to jumper it. |
I need sim pinout for this phone, it is possible? Thanks |
G3 d855 sİm ways urgent friends Urgent friends what sİm ways ???!!! |
Do not have anyone to answer your friends |
hello guyz i had this LG G3 D850 without sim connector , it was broke on the motherboard around the connector it had few trace away (broke) and capacitors so it was not easy to do i had to workaround to found the sim ways , jump capacitors and rebuild few traces the best thing to do is to get a functional main board and compare it to yours (the broken one) anyway i found this ways so i share i cant garantee if you jump them i will work because i rebuild the traces but i did for the capacitors and it worked i dont have the micro SD ways because i decided to forget it remember i worked on a AT&T D850 D855 looks the same i get signal 2G / 3G / 4G in europe (france) i hope this will help https://goo.gl/photos/zifWvW88HyHGQzHk6 https://goo.gl/photos/1PWhHcUnDjTbxYBA8 https://goo.gl/photos/QC1Vh1U8c57Tf81v6 |
i did not get 3G signal with the original android AT&T ROM so i got root and an marshmallow free AT&T ROM so i get 3G ... |
helpp helpp soliation okkk http://resimyukle.xyz/resim/JHLT <a href="http://resimyukle.xyz/resim/JHLT"><img src="http://i.resimyukle.xyz/JHLT.jpg" /></a> http://i.resimyukle.xyz/JHLT.jpg |
