LG KG270 keypad problum lg kg270 keypad not working give good solution thanx in advance salman |
dear only remove charging jack and after clean the place where charging jack connected,put back the charging jack again |
lg kg270 key pad Charging jack is shot check it clean or remove ur problem is solved |
THX. GOOD solution............ |
plz solve my pro i have sony Eric K550i its mic dosn.t works whats the solution this pro? |
Just Change Charging Block......100 % tested by multi system |
gooooood solution sir it working 1000% thx |
where is the pic i don't anderstand this solution |
thanks brother carry on |
good solution tested 100% |
in my case 3 6 9 # not working solution please ? |
lg kg270 keypad problem same problem here with me i have LG kg270 3 6 9 keypad problem plz help me |
try this link http://forum.gsmhosting.com/vbb/showthread.php?t=822104 or this pic http://img225.imageshack.us/img225/3...ackupbyinf.jpg if not working remove charge base & clean it and mainboard Br, MMDEBILI ( INFO_GSM ) |
your solution here http://forum.gsmhosting.com/vbb/showthread.php?t=904823 |
