07-13-2015, 08:22 | #1 (permalink) |
Major Poster Join Date: Jan 2013 Location: Belarus, Minsk
Member: 1873806 Status: Offline Sonork: 100:1637805 Thanks Meter: 8 | LG Nexus 5 D821 replacement emmc I have available KMVTU000LM-B503 (Samsung I9300/N7100) Repair rom2/3, rpmb 4096 kB and write dump full z3x support for D820 device. Code: Z3X EasyJtag Box JTAG Софт версия. 1.9.1.3 Loading eMMC Addon Firmware... IO: 2800 mV Box С/Н: *************, ,Микропрограмма Вер.: 01.52 Напряжение подтяжки линии CMD :26843 mV Напряжение активной линии CMD :28122 mV eMMC Device Information EMMC CID : 15010056545530304DF117BE2F684FFC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C Изготовитель eMMC: ID: 0015 , OEM ID: 0100 EMMC Date: 04/2012 Rev.0xF1 EMMC NAME: <b>VTU00M</b> , S/N: 398339944 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Раздел 1) Емкость: 4096 kB EMMC ROM2 (Boot Раздел 2) Емкость: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 398339944_20150600_1938.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 32 MMCBLK0P0 (MODEM) Range: [0X80000,0X407FE00] ,Len: 4000000 MMCBLK0P1 (SBL1) Range: [0X4080000,0X417FE00] ,Len: 100000 MMCBLK0P2 (RPM) Range: [0X4180000,0X41FFE00] ,Len: 80000 MMCBLK0P3 (TZ) Range: [0X4200000,0X427FE00] ,Len: 80000 MMCBLK0P4 (SDI) Range: [0X4280000,0X42FFE00] ,Len: 80000 MMCBLK0P5 (ABOOT) Range: [0X4300000,0X437FE00] ,Len: 80000 MMCBLK0P6 (PAD) Range: [0X4380000,0X457FE00] ,Len: 200000 MMCBLK0P7 (SBL1B) Range: [0X4580000,0X467FE00] ,Len: 100000 MMCBLK0P8 (TZB) Range: [0X4680000,0X46FFE00] ,Len: 80000 MMCBLK0P9 (RPMB) Range: [0X4700000,0X477FE00] ,Len: 80000 MMCBLK0P10 (ABOOTB) Range: [0X4780000,0X47FFE00] ,Len: 80000 MMCBLK0P11 (MODEMST1) Range: [0X4800000,0X4AFFE00] ,Len: 300000 MMCBLK0P12 (MODEMST2) Range: [0X4B00000,0X4DFFE00] ,Len: 300000 MMCBLK0P13 (METADATA) Range: [0X4E00000,0X4E7FE00] ,Len: 80000 MMCBLK0P14 (MISC) Range: [0X4E80000,0X5E7FE00] ,Len: 1000000 MMCBLK0P15 (PERSIST) Range: [0X5E80000,0X6E7FE00] ,Len: 1000000 MMCBLK0P16 (IMGDATA) Range: [0X6E80000,0X717FE00] ,Len: 300000 MMCBLK0P17 (LAF) Range: [0X7180000,0X877FE00] ,Len: 1600000 MMCBLK0P18 (BOOT) Range: [0X8780000,0X9D7FE00] ,Len: 1600000 MMCBLK0P19 (RECOVERY) Range: [0X9D80000,0XB37FE00] ,Len: 1600000 MMCBLK0P20 (FSG) Range: [0XB380000,0XB67FE00] ,Len: 300000 MMCBLK0P21 (FSC) Range: [0XB680000,0XB6FFE00] ,Len: 80000 MMCBLK0P22 (SSD) Range: [0XB700000,0XB77FE00] ,Len: 80000 MMCBLK0P23 (DDR) Range: [0XB780000,0XB7FFE00] ,Len: 80000 MMCBLK0P24 (SYSTEM) Range: [0XB800000,0X4B7FFE00] ,Len: 40000000 MMCBLK0P25 (CRYPTO) Range: [0X4B800000,0X4D5FFE00] ,Len: 1E00000 MMCBLK0P26 (CACHE) Range: [0X4D600000,0X791FFE00] ,Len: 2BC00000 MMCBLK0P27 (USERDATA) Range: [0X79200000,0X3AB3FA600] ,Len: 3321FA800 MMCBLK0P28 (GROW) Range: [0X3AB3FA800,0X3AB3FBC00] ,Len: 1600 Done...Presets has been updated... Not replaceable chip? |
09-28-2015, 02:20 | #2 (permalink) |
Major Poster Join Date: Nov 2005 Location: Egypt Age: 35
Member: 201595 Status: Offline Sonork: 100.1641255 Thanks Meter: 1 | Hey buddy, did you tried this method ??? [FIX] Unbrick Nexus 5 stucked in Qualcomm HS… | Google Nexus 5 | XDA Forums tell me if you got anything please |
12-22-2015, 17:40 | #3 (permalink) |
Member: 1873806 Status: Offline Sonork: 100:1637805 Thanks Meter: 8 | No Code: Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Code: Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. |
The Following User Says Thank You to halik-85 For This Useful Post: |
