DCT4Plus Unlock updated - 27 January 2009 Genie DCT4Plus unlock update - Support latest Flash Update v.8.51.20.36794 (New bootrom supported) - Some Bugs fixing - Support re-lock function Genie Firmware v 0.0.0.153 - Some bug fixes related to Epson LCD - New, much clear english font installed - New Settings menu added - LCD Backlight There are 2 options: Lcd timeout on - when running application the display will go off after 20 seconds Lcd timeout off - when running application the display will stay on all the time **Update Genie SD card content with GenieClient.exe to receive all update! Download: Link Thanks goes to B-Phreaks. Best Regards Alan Tan :) |
after update my genie firmware is 0.0.0.153 ;) |
works this version with 2610b 7.04a? unlock/imei repair too? thanks |
Phone Version: V 07.04a 26-08-08 RH-87 (c) Nokia. Phone IMEI sent to network: 011664/00/060xxx Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 3101700000000000 MCC+MNC: 31017 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Sending bootloader: u3_2nd.fia Asic: 0x3168 Dev0: 0x00012C7E Base: 0x01000000, Sector Size: 0x11 Sending Algorithm: u3_amd.fia UEM Rev: 0x53 Unknow processor detected! Uploading SP Locks...Error19! Please update manualy. |
UPP ID 3168 is not included for now In the future when we make the update, it will probably be with credits. Best regards Danny |
for 2760b rm-299 not work too finally say update manually how did that? i install all flashes in phoenix folder but say error. |
just press button "manual";) but maybe it's UPP ID 3168 than it will not work i think, just give it a try greetzzz:D |
yep i did that but cant update manually, ill still making tests with others is working good just in 2760b cant br |
---------------------------------------------- Reading Phone Info....Error! Restarting Phone...Done. Phone Version: V 06.82 26-09-08 RM-394 (c) Nokia Phone IMEI sent to network: 356841/02/xxxxxxx Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 2191000000000000 MCC+MNC: 21910 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! |
Reading Genie Universal device...Done. Genie Universal Serial Number: 1xxxxx Genie Universal Hardware version: 01.06 Genie Universal Device Build: 00.00.00.153 Device credits: 0 Searching DCT4 Loaders... ->DCT4 Loaders Dir('Flash')......Found. -->11 file(s) found. -->Loaders version: v. 8.51.20.36794 for ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! |
Few reason for this error: 1) Using POP-UP cable. (Only Fbus cable works) 2) Wrong BSI resistor or BSI to GND resistor Best Regards Alan Tan |
regards |
7100s is upp 0X3168 man , first try and then post, genie dont support that id , we are waiting for 2610b 7.04a upp 3168 even with credits before ub gives unlock free . |
