does this phone have SL3 security? hi, i have error 15 ! Init Fbus, Wait Phone Boot...Done. Reading Phone Info&SimLock...Done. SW Version: V 05.80 18-12-08 RM-495 (c) Nokia ImeiNumber: 354223033****** Config Key: 7300300036615151 Profl Bits: 8000000000000000 Code Count: 0.0 Lock Stat0: Closed 73003f ------------------------------------------------- Open file...Done. Checking file...Done. File: 0B5000039D2E7F56890D1F5144F67BC8D45CE364.rpl Init Fbus, Wait Phone Boot...Done. Uploading New Simlock Data...Error15! is this phone sl3 secure? model is 5130c-2 thanks |
ok thank you but its sl3? |
its not an sl3 phone...but chipsets not supported. |
OK thank you very much for this info.... maybe in some times Bphreak&co will work on this? ;) wbr |
yes its not sl3 .but not supported yet. |
Yes, it is PA_SL3, and Root hash is 9DDBF.. HASH is supported but SIM Lock has new security, If you have MX-Key try to upload SIM Lock rpl with it, Regards, Ali |
Have probe whit MX-KEY, and can not upload... :( |
Can you please post logs in mx-key section ? because I wants to check logs/Error, maybe the simlock is depent to other PM fileds ? not same as PA_SL2. Regards, Ali |
so thank you! so my question i, how to check before if PA_SL3? because i was thinking sl3 firmware was xx.xx not 0x.xx for exemple 5310 v58.58 is sl3, but for me v05.80 was sl2. so is there a tricks for know? thanks |
Regards, Ali |
depending on operator u can unlock it by codes ;) |
http://forum.gsmhosting.com/vbb/show...8&postcount=12 |
Yes Simlock cannot be Uploaded with mxkey either |
