02-03-2010, 11:43 | #6 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | genie update problem bro connect usb cable genie to pc then go to in genie open right side option is mode & run usb disk option then open update clint in ur pc click get drive showing ur genie drive with ur genie serial no in block click ur genie drive (showing with ur genie serial no) see is under blue then click update & w8 ur genie update aoutomatcly in few minute |
02-03-2010, 11:57 | #7 (permalink) |
Registered User Join Date: Dec 2005
Member: 205989 Status: Offline Thanks Meter: 13 | -------------------------------------------------------------------------------- Quote: Originally Posted by san21 when i click update error ....... pelase update vide or manual give me sir i posted picture solution genie team? help sir bro connect usb cable genie to pc then go to in genie open right side option is mode & run usb disk option then open update clint in ur pc click get drive showing ur genie drive with ur genie serial no in block click ur genie drive (showing with ur genie serial no) see is under blue then click update & w8 ur genie update aoutomatcly in few minute I also try by this system but can't update pls. help me |
02-03-2010, 19:09 | #14 (permalink) |
No Life Poster Join Date: Aug 2000 Location: anywhere
Member: 1879 Status: Offline Sonork: 100.28016 Thanks Meter: 941 | the update-client server is right now down because we are updating some files on it. will be online by tomorrow again. regards, |
The Following User Says Thank You to John_Doe For This Useful Post: |
error on genie box | shak360 | Genie Universal | 14 | 01-07-2010 11:43 |
After upgrade box show ERROR | umeshpitroda | HWK | 5 | 10-11-2008 16:38 |
