Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Genie Universal
Old 03-26-2009, 17:34   #1 (permalink)
Freestyler2000's Avatar
Member: 2868
Thanks Meter: 514
New version of BB5 No Test point application
v 0.0.0.110 - 26.03.2009
- RAP3 SL2 unlocking is completely free
now, no need to keep 200 credits to be
able to use it. Please feel free to use
them for other services like RAPIDO SL2
or DCT4+ RPL
- Some quick fix on the 5800 unlock problem
the code will be saved to the card. If you
get success on unlock, but phone is still
locked, please do not try to do it second
time as this will eat another 50 credits.
Just run the provided script to enter the
saved code again and unlock
Please use the Genie Update utility to get the latest version on your device
Best regards
Danny
File Type: zip code.zip (827 Bytes, 300 views)
The Following 22 Users Say Thank You to Freestyler2000 For This Useful Post:
Old 03-27-2009, 00:26   #2 (permalink)
wisam_wa's Avatar
Member: 103945
Sonork: 100.112828
Thanks Meter: 355
- please do not try to do it second
Danny
thanx but how can download this script
is script make when i try unlock or must download plz can you post more details about this
thanx
Old 03-27-2009, 05:30   #3 (permalink)
Member: 90761
Sonork: 1617079
Thanks Meter: 95
or DCT4+ RPL
Best regards
Danny
sory sir, u mean all genie user (not active bb5+) can use it? or must buy activated before use?
Old 03-27-2009, 07:29   #4 (permalink)
Member: 515413
Thanks Meter: 146
off sure,now u can use unlock bb5+ except rapido sl2 without buy 200 credit minimum..
Old 03-27-2009, 10:58   #5 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
thanx
Hi,
The script is attached to the first post. Please download and extract.
Then put code.amx in your Programs/Script directory. How to use:
1. After unlocking 5800 and get success, check with simcard if the phone
has really accepted the unlock code.
2. If not, connect the phone again and start code.amx
3. The script will wait 15-20 seconds for the slow os to boot and will try
to load the code again. If you get blinking ( sometimes RAPIDO suck
GigaWatts of power), just mess around with the resistors, plug, unplug
during the Waiting to bootup message on screen till you you get stable
Local Mode
You will get success on unlocked phone too. Also only the last generated
code will be saved to card and uploaded to the phone. So if you have other
phones to unlock, please do not do them until you load the code to the
problematic 5800.
We are still waiting for a sample phone, so please check if the current 15 s
timeout is enough.
Regards, Alex
The Following 4 Users Say Thank You to Bph&co For This Useful Post:
Old 03-27-2009, 12:41   #6 (permalink)
unlockgod's Avatar
Member: 5285
Thanks Meter: 82
Wink
Genie universal 1st in the world with pa_sl2 for free!!!! no need a credits not even 200
alan tan is the man!!!!
Old 03-27-2009, 15:50   #7 (permalink)
wisam_wa's Avatar
Member: 103945
Sonork: 100.112828
Thanks Meter: 355
Originally Posted by Bph&co View Post
Hi,
Local Mode
problematic 5800.
timeout is enough.
Regards, Alex
thanx bro i have some 5800 i check and test this method and i will post in success thread result i hope make easy way to all member if i found some defecult in some model
Old 03-27-2009, 15:57   #8 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
what so is is free with this clip now to unlock the 5800 and n96 ect?
Old 03-27-2009, 16:10   #9 (permalink)
Member: 633
Thanks Meter: 37
No.
U only dont need to have at least 200credits remaining in genie clip to unlock bb5+
B.R.
Zoio
The Following User Says Thank You to Zoio For This Useful Post:
Old 03-28-2009, 17:35   #10 (permalink)
Member: 147105
Thanks Meter: 8
..and you test to unlock nokia 5800 with this method or not....when yes...its works.....can post the result and what you do.....
br
felix999
Old 03-28-2009, 21:29   #11 (permalink)
wisam_wa's Avatar
Member: 103945
Sonork: 100.112828
Thanks Meter: 355
br
felix999
tested 100% see this link
http://forum.gsmhosting.com/vbb/show...6&postcount=40
Old 04-01-2009, 12:11   #12 (permalink)
Member: 98828
Thanks Meter: 76
Hi,
Local Mode
problematic 5800.
timeout is enough.
Regards, Alex
Hi
i have unlock many 5800 without any problem after i found this problem only happened after the phone been debrand.
i got 2 set of 5800 been debrand,when i unlock. it show unlock done and credit teken,but when insert sim and test..it show sim lock.
but i manage to solve this problem by flash the phone back to original product code and unlock again. then the phone is unlocked.
so..my experiance is..if you need to debrand you phone and unlock too...please unlock first. debrand later. all will be ok. no lost credit after this.
hope this info is help,
thanks
gsmuk
Old 04-01-2009, 21:22   #13 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Originally Posted by gsmuk View Post
Hi
thanks
gsmuk
Hi,
Thanks for the interesting info! Did you full flash the phone or just change
the product code back to original ?
Old 04-02-2009, 00:27   #14 (permalink)
Member: 98828
Thanks Meter: 76
Hi,
Hi
I full flash the phone back to english version ( original is uk local phone)
so far discover 2 set after flash chinese language ,this problem happened. ( 100 credit to learn this error :-) hehe ) , so i believe most of your complain about 5800 is those customer unlocking the phone after they debrand it.
after i discover this problem. i always unlock first . then i flash any language with phoenix or jaf. no problem at all. the phone remain unlocked. done more then 100 set without any problem after this.
thanks
gsmuk
The Following User Says Thank You to gsmuk For This Useful Post:
Old 04-02-2009, 14:00   #15 (permalink)
Celui's Avatar
Member: 906535
Thanks Meter: 46
Is there currently a server problem? I have been trying to update with Genie Client since yesterday and it keeps returning 'Error!'
Celui
New version of BB5 No Test point application Freestyler2000 Genie Universal 1 04-10-2009 04:12
Genie Universal new version of BB5 No Test point application Freestyler2000 Service Products News & Updates 0 03-26-2009 17:48
list of bb5 without test points kully Universalbox 3 11-29-2008 17:19
bb5 no test point announcement bb5uk Nokia Base Band 5 ( BB-5 ) 1 01-04-2008 22:06
Page generated in 0.42514 seconds with 10 queries
