06-05-2009, 15:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Dublin
Member: 16771 Status: Offline Thanks Meter: 153 | GENIE Questions There seems to be no decent user guide. Can you confirm what buttons turn the device on/off and what the numbers buttons are used for? Best Regards Alan Donohoe GSM Ireland Group www.GSMireland.com |
06-05-2009, 15:39 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @gsm genei auto power when u plug usb cable and auto off when u remove buttons depend on which option ur using unlocking user code remove etc in ! Week u will learn how to use this box dont worry regards |
06-08-2009, 14:14 | #4 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | i have a question everytime i unlock phone with BB5notp it unlock sucessfull but when i try to close program it don't close.. when i click on quit.. it not freezing or anything just that it don't close. i have to power it off by taking out battery .. any solution to fix that problem ? |
06-08-2009, 14:21 | #5 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @gsm Code: use any one of software like bb5notp u will be practical after using not before that Code: yes this issue sometimes get to all use without batt ur genie use direct usb power cable |
06-09-2009, 14:45 | #9 (permalink) |
Member: 16771 Status: Offline Thanks Meter: 153 | Thanks all. However, the 2 units i have Will Not turn on Using number '1'? I have fully charged the battery, once unplugged and turned off, the device will not power on unless plugged in.... Can anyone explain what the fault is or is this just a common fault you know about already? Without portability these devices are useless for the purpose i purchased them for. Br Alan |
06-09-2009, 19:08 | #10 (permalink) |
Junior Member Join Date: Nov 2004 Location: Among phones Age: 50
Member: 92647 Status: Offline Thanks Meter: 3 | I suppose you have updated your SD card to the last version... Of course you mustn't have plugged the AC adaptor neither the usb cable. Push reset button from back of Genie (push and release) and wait to reset, then push button "1" for 4 seconds at least and release the button; Genie must be OFF in this point. Press again button "1" for TWO seconds and release the button. Genie MUST be ON here. If not, something is wrong in your box. B.R. |
06-11-2009, 13:42 | #13 (permalink) |
Member: 16771 Status: Offline Thanks Meter: 153 | Thanks. Its the same with both batteries/box. Its an intermitten fault, the batteries are Full. Its not a battry fault. Given thats its the same fault with both boxes i find it a little strange you have never encountered this before. So, if its not the battery, what do you think the fault is? Br Alan. |
06-11-2009, 15:49 | #14 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 57803 Status: Offline Thanks Meter: 99 | I have exactly the same fault, sometimes if I disconnect/reconnect the battery it will turn on using the '1' button but most of the time I have to plug it into the mains for it to work. To be honest it was a pain in the ar*e so now I just use mains power. This is a great piece of kit for unlocking Nokias, and as I only use it in my shop this fault doesn't cause me a problem. |
06-11-2009, 17:45 | #15 (permalink) |
Member: 16771 Status: Offline Thanks Meter: 153 | Well so far i have unlocked every Nokia i tried without problem, so from that point it works fine, however, as i need it when i'm away from the shop its quite useless unless it turns on.. I hope official support can shed some light on this and help me find a solution? Br alan |
Question regarding credits [ANSWERED] | ravikumar.boddu | PolarBox 3 | 3 | 03-29-2010 15:19 |
One Question About Cruiser,pls | Gubby_J | Cruiser Suite | 2 | 03-29-2010 12:46 |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
Quick Question how do u flash with genie | faisal butt | Genie Universal | 4 | 12-08-2009 02:57 |
Questions to genie universal | AOYUE | Genie Universal | 4 | 08-02-2009 20:53 |
