Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Genie Universal
Old 06-11-2009, 20:57   #16 (permalink)
mobymaster's Avatar
Member: 13975
Thanks Meter: 7
Does battery display reading in the system info , / give voltage readings when connected to a multimeter?
I gave up relying on the battery in my unit and opend it up, used the wiring from it, and made my own battery from two motorola v3. Providing the output is 7.2 you should be OK. Wire them up +ve on battery B to -ve on battery A, +ve on battry A to +ve on pcb (or switch here if your interested in adding one), -ve on battery B to -ve on pcb.
Its what I did with my own device and have no issues with it what so ever. Works fine for me.
Obviously this is only useful for you, if it is a fault with the batteries.
Old 06-11-2009, 22:40   #17 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Hi,
Thanks for reporting this. I will check if battery management is damaged somehow in latest version
of the OS.
Old 06-12-2009, 08:29   #18 (permalink)
Member: 57803
Thanks Meter: 99
This problem seems to occur when Genie goes into 'battery saving mode' it will not power up again unless I disconnect/reconnect the battery or plug it into the mains.
Is there a way to disable this 'saving mode' then a least GSM Solutions could just carry a spare fully charged battery on his travels.
I appreciate this doesn't solve the problem fully but at least it gets him back on the road.
Old 06-12-2009, 13:33   #19 (permalink)
GSM Solutions Ireland's Avatar
Member: 16771
Thanks Meter: 153
Cheers,
Taking the battry out and reconnecting it seems to work, its just a headache having to do this, also even with a fully charged battery it seems to waste within 24 hours of standby.
Alan
Old 06-12-2009, 14:02   #20 (permalink)
mobymaster's Avatar
Member: 13975
Thanks Meter: 7
@ GSM Solutions Ltd
Im experiencing similar issues. Ive never noticed them before, as ive just turned the device off after use. But it looks like when the device goes into sleep mode, only way to get it to wake up, is to kill power, and reboot. Same when running from USB cable for power, or running from internal battry.
If you do my suggestion, if it does die, you have a button you can manually kill power. UNless you want to open up the device and mess around unplugging wires.
Before ******* my switch, i just had the wires out the casing with the red clip together, and unplugged it.
Old 06-12-2009, 15:55   #21 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
just press reset button, its easy
Old 06-12-2009, 18:32   #22 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Hi,
I still can't recreate this problem. Device is running on battery. Its in the main menu, after
few seconds it goes to low power mode. It appears fully dead, pressing buttons will not
change anything.
Then press '1', hold for 1 second and release, device wakes up.
I will need more info to recreate the problem all you're having.
Old 06-13-2009, 12:19   #23 (permalink)
Member: 16771
Thanks Meter: 153
Turning sleep mode off may solve this, can this be done?
Alan
Old 06-13-2009, 13:29   #24 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Hi,
Everything could be solved if there is a problem. If there isn't one, i see no point to fix anything.
Old 06-13-2009, 17:48   #25 (permalink)
Member: 16771
Thanks Meter: 153
Well, there is a problem.
It wont turn on sometimes even if battery is full.
Old 06-13-2009, 20:58   #26 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Ok,
But since my telepathy skills are not very good I will appreciate some more info.
Maybe full description of the problem, some analysis of the 'sometimes' conditions, etc.
Thanks
Old 06-14-2009, 20:25   #27 (permalink)
mobymaster's Avatar
Member: 13975
Thanks Meter: 7
I find it happens when running any application, bb5unlocker, geniep, fls5, operation is completed / running fine, but display goes blank. No matter what key you press for how long, only way to reset device is to remove usb/mains if connected, and disconnect battery *or turn off via switch*
When turn back on power it boot normally.
If i keep pressing a key during operation, display is fine.
Maybe option for customer to choose idle timeout function?
Old 06-14-2009, 23:10   #28 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Hi,
So if I understand this correct, this blocking you get is during using an application.
You can try to select LCD timeout off from the Setting menu and see if this blocking
happens as well.
Old 06-15-2009, 14:28   #29 (permalink)
Member: 16771
Thanks Meter: 153
Originally Posted by Bph&co View Post
Ok,
Thanks
I believe if you read the previous posts in this thread you should understand what the problem is......
Question regarding credits [ANSWERED] ravikumar.boddu PolarBox 3 3 03-29-2010 15:19
One Question About Cruiser,pls Gubby_J Cruiser Suite 2 03-29-2010 12:46
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
Quick Question how do u flash with genie faisal butt Genie Universal 4 12-08-2009 02:57
Questions to genie universal AOYUE Genie Universal 4 08-02-2009 20:53
Page generated in 0.17540 seconds with 9 queries
