Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Genie Universal
Old 07-21-2012, 15:43   #61 (permalink)
Member: 87188
Thanks Meter: 231
Thanks!
Looking for phone...Not found!
Can't read IMEI, backup will be skipped.
Looking for NAND disk...Done.
Trying to parse partition tables...Done.
FAT16 absolute address: 0x001F4200
FAT16 partition size: 0x0927C000
Searching locations...Done.
Found 1 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
"alternative search for old pc" and OK.
Old PC?
My PC: AMD 1100T 6 core, 4GB ram, (XP32bit)
Then old pc...
restore bootloader not work:
Looking for phone...Done.
Device: RM-803-NOKIA Lumia 710
Battery status: 87%
Changing phone mode...
then that's Forever....
The Following User Says Thank You to Pufi164 For This Useful Post:
Old 07-21-2012, 22:03   #62 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 705
Same prob i have an i7 4gb ram 2x ati 6950!!
Originally Posted by pufi164 View Post
thanks!
Looking for phone...not found!
Can't read imei, backup will be skipped.
looking for nand disk...done.
Trying to parse partition tables...done.
fat16 absolute address: 0x001f4200
fat16 partition size: 0x0927c000
searching locations...done.
Reading sector 0...done.
Modify sector...done.
Updating sector...done.
1. Disconnect usb cable and remove the battery
3. If asked for pin code, enter 00000000
4. If asked for puk code, enter 0000000000
5. After unlock success, connect to usb, enter osbl mode
6. Press unlock again to restore the phone to original
"alternative search for old pc" and ok.
Old pc?
My pc: Amd 1100t 6 core, 4gb ram, (xp32bit)
then old pc...
Restore bootloader not work:
Looking for phone...done.
Device: Rm-803-nokia lumia 710
battery status: 87%
changing phone mode...
Then that's forever....
i guess prob is with windows xp!!!
Old 07-22-2012, 11:44   #63 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Old PC?
Then old pc...
If your motherboard is not Asus Rampage, CPU i7 3930 4Ghz, 32 GB RAM 1866,
HD 512GB SSD with 1Gbps write speed - it seems your PC is old
On a serious note, the error from Windows on ReadFile() is Insufficient resources.
Although large buffer is allocated for read without error, it seems there is
internal buffering somewhere, maybe in the drivers and that's why the
read fail, probably XP is the reason.
The Following 3 Users Say Thank You to Bph&co For This Useful Post:
Old 07-22-2012, 12:48   #64 (permalink)
Member: 1123898
Thanks Meter: 15
Please help, on what mode will the lumia 800 be connected to PC before unlock?
Old 07-23-2012, 16:43   #65 (permalink)
dawood1208's Avatar
Member: 1093004
Thanks Meter: 4,382
How to unlock bootloader in lumia 800
Which file i have to flash ??
Old 07-23-2012, 19:18   #66 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,195
Tick "Flashing" > "WP7 Tools" > "Install"
Old 07-24-2012, 19:35   #67 (permalink)
Member: 64823
Thanks Meter: 440
One Question will this work on DLOAD LUMIA 800 RM-801 !!
Old 07-24-2012, 23:13   #68 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 498
@Bph&co
I Read All Thread But Still Confused
Bro Can You Step By Step With Images Help Us ?
1-How To Root? How To Check Either Rooted Or Not?
2-Unlocking Process After Rooting?
We Are Not Genious Like You Plz Help Us................
Thanks Anticipation...................................... ......
Old 07-25-2012, 00:26   #69 (permalink)
Member: 1123898
Thanks Meter: 15
Please post step by step because there is no user manual for the software so we are still crawling in the dark on the use of this...
Old 07-25-2012, 02:20   #70 (permalink)
nofear99's Avatar
Member: 1157693
Thanks Meter: 122
Question Lumia 800 wiith dload drivers ?????
Lumia 800 with dload not qualcom
how to unlock bootloader
is it possible???
Old 07-25-2012, 02:43   #71 (permalink)
asmodi's Avatar
Member: 183976
Thanks Meter: 134
@Bph&co
Its very simple :
to root a lumia 710 u must add this 2 files to NssPro_0.51_2_b\loaders\special\wp7 :
1-RM803_12w07_prod_generic_nokia_osbl.esco
2-RM803_12w07_prod_generic_adsp.esco
then turn off your phone then press volume"+" and press power until the phone vibrate then install drivers .
then go to "flashing" then to "WP7 Tools" then press install.
after u root your phone go to "simlock" then "WP7" the press "unlock"
for lumia 800 i can not find the necessary files for root , but if your phone is auredy rooted u can unlock it with this soft .
(when u press volume "+" and press power until the phone vibrate , connect your phone to the pc , if the phone is detected as "nokia dloed " that's mean that ur phone is not rooted and u must root it )
The Following User Says Thank You to asmodi For This Useful Post:
Old 07-25-2012, 11:33   #72 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Hi,
I have spent so much time and money to make this solution. I give it to you
free and you complain that you have to spend 10 minutes of your time to
make it work. All the info is available online since April when WP7 was hacked.
I also have lots of work, maybe some nice user will make detailed guide and
share. I have some info posted in forums here and there, also have updated
the NssPro.pdf, but not that detailed.
The Following 4 Users Say Thank You to Bph&co For This Useful Post:
Old 07-25-2012, 11:52   #73 (permalink)
Member: 87188
Thanks Meter: 231
Pay-solving, are interested!
Old 07-25-2012, 15:47   #74 (permalink)
akh84's Avatar
Member: 1733938
Sonork: 100.1617311
Thanks Meter: 34
report OK Lumia 800
Reading FAT16 raw...Done.
The Following 2 Users Say Thank You to akh84 For This Useful Post:
Old 07-25-2012, 23:04   #75 (permalink)
Member: 1123898
Thanks Meter: 15
did you connect this in normal mode then obsl after the modification?
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.21350 seconds with 10 queries
