07-31-2012, 12:38 | #91 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 262 | When i pressed the Volume + and power, it will go to DLOAD MODE and not in the qualcom mode |
07-31-2012, 16:21 | #92 (permalink) | |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | error sending bootloader !!! Quote:
If Is sure that 710 boot loader donīt Work in 800 why all people says the same that is the sames two files bootloader ??? Anyone that really unlock an LUMIA 800 with this programs please ??' | |
08-01-2012, 12:41 | #94 (permalink) | |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
Thousands of people, just need to read what has been posted before. If the 800 comes with Qcom loader from the factory, then you can unlock it. If your phone came with the Nokia DLOAD loader, you are out of luck. BR | |
The Following User Says Thank You to Bph&co For This Useful Post: |
08-01-2012, 22:55 | #95 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks Meter: 23 | what can i do boss with this error Looking for NAND disk...Not found. - Looking for phone...Done. IMEI: --------------------------------------- Please follow these steps: 1. Power off the phone 2. Remove the USB cable 3. Press and hold the Vol+ button 4. Plug the USB cable, wait for the buzz 5. Release the Vol+ button --------------------------------------- Waiting for 30 seconds...Done. ---------------------------------------------------------------------------- Looking for NAND disk...Not found. Things to check: 1. Is the phone connected?(Plug to the USB) 2. Is it in the correct mode?(Try to switch to OSBL mode) 3. Have you installed the Qcom loader ?(Use the Install button) |
08-04-2012, 04:59 | #97 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Sir, Wat about LUMIA 610, Is this also unlockable ? Bcoz i searched but couldnot find it unlocked..I fear it does not go wrong bcoz its little different from Other types of NOKIA,,cannot save its RPL or simlock pm etc..plz sir guide me on this also. BR | |
08-09-2012, 02:25 | #98 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Pakistan
Member: 170380 Status: Offline Sonork: 100.1577994 Thanks Meter: 3,022 | Quote:
08-10-2012, 02:42 | #100 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 500 | Error in install lumia 710, any heelp ? Preparing update...Done. ------------------------------------------ Init connection...Done Enter flash mode...Done Enter bootloader mode...Done Boot version: 240.116.132.78 Sending certificate...Failed. ------------------------------------------ Restart and exit flash mode...Done. ------------------------------------------ To enter MSD mode: 1. Power off the phone 2. Remove the USB cable 3. Press and hold the Vol+ button 4. Plug the USB cable, wait for the buzz 5. Release the Vol+ button (or you can change mode to OSBL in NSS) ------------------------------------------ WARNING: If you get Format Disk message in Windows - always click Cancel !!! ------------------------------------------ Phone details: NCSD Version: 1.5 SW Version: 1600.3013.8107.11502 HW Version: 112.1402.2.1 IMEI: 359300044700426 Product Code: 059M740 Basic Product Code: 059H4J0 Module Code: 0204985 Production SN: MQO443801 Public ID: 6938B325AB1D179551D03759CFDE215D WLAN MAC: 6CE9072E96AF0000 Battery life: 55% Nss detect phone in mode: Nokia usb connectivity |
08-10-2012, 10:48 | #101 (permalink) |
Member: 853601 Status: Offline Thanks Meter: 262 | Restart and exit flash mode...Done. ------------------------------------------ To enter MSD mode: 1. Power off the phone 2. Remove the USB cable 3. Press and hold the Vol+ button 4. Plug the USB cable, wait for the buzz 5. Release the Vol+ button (or you can change mode to OSBL in NSS) ------------------------------------------ WARNING: If you get Format Disk message in Windows - always click Cancel !!! ------------------------------------------ Phone details: NCSD Version: 1.5 SW Version: 1600.3013.8107.11502 HW Version: 112.1402.2.1 IMEI: 359300044700426 Product Code: 059M740 Basic Product Code: 059H4J0 Module Code: 0204985 Production SN: MQO443801 Public ID: 6938B325AB1D179551D03759CFDE215D WLAN MAC: 6CE9072E96AF0000 Battery life: 55% Nss detect phone in mode: Nokia usb connectivity If your phone detects on that kind, not supported for openline phone must be detected as QUALCOM and NOT NOKIA CONNECTIVITY |
08-10-2012, 16:51 | #102 (permalink) | |
Member: 85718 Status: Offline Thanks Meter: 500 | Quote:
I know in that mode canīt unlock, but when i try to use the INSTALL option give the message i have posted, if i try to use INSTALL using this sequence To enter MSD mode: 1. Power off the phone 2. Remove the USB cable 3. Press and hold the Vol+ button 4. Plug the USB cable, wait for the buzz 5. Release the Vol+ button (or you can change mode to OSBL in NSS) the error is the same, in this mode is i goes to windows properties the phone is conected in DLOAD mode. Is this drivers correct to use the DLOAD mode ? Last edited by ct3im; 08-10-2012 at 17:00. | |
08-11-2012, 10:48 | #103 (permalink) | |
Junior Member Join Date: Oct 2010
Member: 1407767 Status: Offline Thanks Meter: 2 | reply Quote:
Hey. lumia 800 (Nokia DLOAD) mode, you can unlock? Greetings | |
08-12-2012, 19:33 | #105 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Lebanon-Beirut Age: 43
Member: 180903 Status: Offline Thanks Meter: 70 | help need to unlock lumia 800 nsspro Looking for phone...Not found! Can't read IMEI, backup will be skipped. ---------------------------------------------------------------------------- Looking for NAND disk...Not found. Things to check: 1. Is the phone connected?(Plug to the USB) 2. Is it in the correct mode?(Try to switch to OSBL mode) 3. Have you installed the Qcom loader ?(Use the Install button) |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
