Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Genie Universal
Old 08-15-2012, 04:01   #106 (permalink)
Member: 979862
lumia 800 don't unlock ,help FAT16 absolute address: 0x001F4200
FAT16 partition size: 0x0927C000
Reading FAT16 raw...Done.
Searching locations...Done.
Found 1 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
enter 00000000 don"t success help
Old 08-15-2012, 09:32   #107 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
with NSS i have this log phone lumia 800 in normale mode
Looking for phone...Done.
IMEI: 359289xxxxxxxxxx
Please follow these steps:
1. Power off the phone
2. Remove the USB cable
3. Press and hold the Vol+ button
4. Plug the USB cable, wait for the buzz
5. Release the Vol+ button
Waiting for 30 seconds...Done.
Looking for NAND disk...Not found.
Things to check:
1. Is the phone connected?(Plug to the USB)
2. Is it in the correct mode?(Try to switch to OSBL mode)
3. Have you installed the Qcom loader ?(Use the Install button)
when Press and hold the Vol+ button and plug the USB cable phone turned on
already update to last firmware with zune
pls any help!!
Old 08-15-2012, 19:03   #108 (permalink)
Pastime_GSM's Avatar
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,057
Things to check:
pls any help!!
hello;
that's mean you have no luck cos your phone with locked bootloader
not supported yet for unlock
br
Pastime_GSM
Old 08-15-2012, 19:19   #109 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 793
you see new nokia with hw rev is 2.4 and your Lumia came with firmware 11500 or higher you have the new nokia bootloader.
even if u have 2.3 and flashed with flashed your device with a firmware 11500 with Nokia Care Suite - you have the new Nokia Bootloader
go to "Settings -> About -> more info and if your "Hardware revision number" ends with 2.4 i think you cannot downgrade bootloader atm so no
and NOKIA DLOAD to put Qualcomm bootloader only if you have a Lumia 710, on the 800 is not possible at the moment.
try exemple
hardware revision number 002.1402.2.3
possible to unlock lumia 800
hardware revision number 002.1402.2.4
not supported for unlock lumia 800
The Following User Says Thank You to ABOUSHADY For This Useful Post:
Old 08-15-2012, 20:12   #110 (permalink)
asmodi's Avatar
Member: 183976
Thanks Meter: 134
Send a message via ICQ to zinoubinabil
Things to check:
pls any help!!
Try to hold volume + and press power until the phone vibrate after insert cable then install the correct drivers ...
Old 08-15-2012, 21:17   #111 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,057
hello
i have the same problem with xxxxx.2.3 hardware version
Firmware revision number: 1750.0805.8773.12220
Hardware version number: 112.1402.2.3
Bootloader VERSION/ 7.41.0.0
Ship SOC VERSION/ 0.74.2.1
Old 08-15-2012, 22:25   #112 (permalink)
forhike's Avatar
Member: 14934
Thanks Meter: 79
Will it be posibly to make this work on genie clip ? =)
would be nice to use it again
b.r
The Following User Says Thank You to forhike For This Useful Post:
Old 08-17-2012, 00:41   #113 (permalink)
Cheater -Don't Deal with him-
Member: 770863
Sonork: 100.1597188
Thanks Meter: 123
Originally Posted by basqui View Post
will this work on dload detected unit? meaning the ones not rooted yet?
you need to root first if u want to unlock lumia
Old 08-17-2012, 00:42   #114 (permalink)
Member: 770863
Sonork: 100.1597188
Thanks Meter: 123
Originally Posted by maazi View Post
Hello, to unlock lumia i have to connect the Genie Universal ? and i also have to update the firmware? thanks
no need to connect any box just need usb cable
its free software
Old 08-17-2012, 00:46   #115 (permalink)
Member: 770863
Sonork: 100.1597188
Thanks Meter: 123
i have lumia 710 rm-809 can i unlock this? if yes which file i use for flashing and how i unlock thanks
all details are in first post bro
read it completely hope u will get ur answer
Old 08-17-2012, 14:09   #116 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 793
Originally Posted by Pastime_GSM View Post
hello
Hardware version number: 112.1402.2.3 this u can unlock it
Old 08-20-2012, 19:54   #117 (permalink)
Member: 188715
Thanks Meter: 31
NCSD Version: 1.9
SW Version: 1750.0805.8773.12220
HW Version: 112.1402.2.3
IMEI: 35*************
Product Code: 059L7H0
Basic Product Code: 059J2N6
Module Code: 0205051
Production SN: 0055589AB
Public ID: 1A8868F613A2CC33F16447D7311B36C3
WLAN MAC: 6CE9079D7C9E0000
Battery life: 86%
Number of Nams: 1
Number of Mins: 2
ESN: 00000000
ESN Decoded: 0
PRL Version: 65535
Battery Charge Capacity: 1337mA
Battery Full Capacity: 1347mA
Battery Cycle Count: 65535
Battery Temperature: 331
Battery Voltage: 4197mV
Battery State of Charge: 86%
Battery Average Current: 199mA
Battery Flags: 296
Battery Standby Current: -4mA
Battery MaxLoad Current: -800mA
Battery Health State: 853
Battery Nominal Capacity: 1158mA
Battery Remaining Capacity: 1148mA
please, some help!
if i put phone in OSBL mode, it vibrate shortly. in device manager appears "Qualcomm CDMA Technologies MSM" , but no drivers found. i installed corectly all the drivers. i am searching a solution to solve my problem, but nothing found in last 7 days
i tried this on 2 pcs WIN7, 2 laptops WIN7, 1pc WINXP. no luck. i even run ubuntu into a virtual machine. it displayed "Qualcomm CDMA Technologies MSM" , i done the connection, but the drive Qualcomm MMC does not appear in device utility.
Old 08-21-2012, 13:40   #118 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Hi,
There is not a single Mass Storage Device that Windows 7 will not be able
to auto mount, install driver, etc. Never heard, even on 10 year old XP
somebody to search drivers for USB flash stick. And this is what Qcom
bootloader is - makes internal eMMC flash visible as USB flash disk.
Old 08-23-2012, 05:58   #119 (permalink)
Member: 188715
Thanks Meter: 31
"no drivers found" is win7 message
sorry for my bad english. still searching for solutions...
Old 08-28-2012, 08:39   #120 (permalink)
Member: 74879
Lumia 710 root
HI i've been trying to root my phone
Preparing update...Done.
Init connection...Done
Enter flash mode...Done
Enter bootloader mode...Done
Boot version: 240.116.132.78
Sending certificate...Failed.
Restart and exit flash mode...Done.
To enter MSD mode:
(or you can change mode to OSBL in NSS)
WARNING: If you get Format Disk message in Windows -
always click Cancel !!!
After this my windows shows Nokia DLOAD, but not qcom. What am i missing?
Thanks
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.23932 seconds with 10 queries
