12-11-2008, 04:00 | #4 (permalink) | |
Freak Poster Join Date: May 2003 Location: Canada
Member: 29222 Status: Offline Thanks Meter: 10 | Quote:
Bro, try with: 1. Iphone firmware, Boost mode, Patch count = 5 2. Turn off 3G and data roaming on iphone. The turn off the iphone completely. 3. Put the desired sim into an unlocked phone or a phone that can use the desired sim and let it catch a network signal. 4. Then insert the yessim with the above settings into the iphone and turn it on. You should catch a signal within 30-40 seconds. Anytime you try to use 3G or go into airplane mode, repeat steps 2-4 again. Hopefully there will be a fix out for the 3G soon. | |
12-13-2008, 01:49 | #5 (permalink) |
No Life Poster Join Date: Sep 2003
Member: 38307 Status: Offline Thanks Meter: 66 | you can use YESSLIM with the following setting: firmware: iPhone Firmware MMC-MNC: 001-01 BOOT MODE IMSI PATCH COUNT: 1 or 30 this will work, even if you jailbreak the phone. |
iphone 2g 2.0 not unlock! | GSMBOURGES | YESSIM | 3 | 09-02-2008 16:46 |
