Tell me any CPF-BOX problem Tell me any CPF-BOX problem or help, i try to give solution.just post ur problem and w8. Me all time here... Br, parash |
My CPF-BOX the voltage is excessively low Can't find pin out. Is Voltage testing... When circuit 1(6) set VCC, the voltage is excessively low, the value is 1.69v When circuit 2(8) set VCC, the voltage is excessively low, the value is 1.09v When circuit 3(10) set VCC, the voltage is excessively low, the value is 1.69v When circuit 4(12) set VCC, the voltage is excessively low, the value is 1.16v When circuit 5(14) set VCC, the voltage is excessively low, the value is 1.69v When circuit 6(16) set VCC, the voltage is excessively low, the value is 1.17v When circuit 7(18) set VCC, the voltage is excessively low, the value is 1.70v When circuit 8(20) set VCC, the voltage is excessively low, the value is 1.10v When circuit 9(21) set VCC, the voltage is excessively low, the value is 1.70v When circuit 10(4) set VCC, the voltage is excessively low, the value is 1.11v When circuit 11(5) set VCC, the voltage is excessively low, the value is 1.70v When circuit 12(9) set VCC, the voltage is excessively low, the value is 1.10v When circuit 13(11) set VCC, the voltage is excessively low, the value is 1.70v When circuit 14(13) set VCC, the voltage is excessively low, the value is 1.09v When circuit 15(15) set VCC, the voltage is excessively low, the value is 1.69v When circuit 16(17) set VCC, the voltage is excessively low, the value is 1.10v When circuit 17(19) set VCC, the voltage is excessively low, the value is 1.74v When circuit 18(22) set VCC, the voltage is excessively low, the value is 1.10v When circuit 19(3) set VCC, the voltage is excessively low, the value is 1.70v When circuit 20(7) set VCC, the voltage is excessively low, the value is 1.10v When circuit 21(2) set VCC, the voltage is excessively low, the value is 1.70v When circuit 22(1) set VCC, the voltage is excessively low, the value is 1.10v When circuit 23(24) set VCC, the voltage is excessively low, the value is 1.69v When circuit 24(23) set VCC, the voltage is excessively low, the value is 1.09v * The voltage test finished. Please give me the solution. Thanks. |
wen i connect my box its allwes display this ! Last update of program file: 11/11/2010 Last update of configuration file: 2010-11-11 Connection success, but no found Port 232BM,retry. Version: V3.1 Connected Port:COM7 Normal Port:COM1 Fast Port:COM7(2303) * Connection success,welcome cpf-box 2. but software work fine, why this err ? (but no found Port 232BM,retry.) |
usb detection fail please help me my box can not detect charge pin or usb. thats reason i can not flash spd cpu phone.............thanks |
how to write 2 imei with cpf.........? |
http://forum.gsmhosting.com/vbb/6383414-post6.html |
same problem after change adapter and usb cabe. |
do system recovery with out attaching any cable with ur box http://forum.gsmhosting.com/vbb/5847705-post1.html try on another pc if still same then check ur box hardware. |
problem Version: V3.1 Connected Port:COM7 Normal Port:Fast Port:COM7(2303) normal port : ??? vcc voltage low please repair guide |
my box rx tx not taking |
how to use detect usb for spd?? |
Br, Parash |
